psxcancel test failure
Sebastian Huber
Sat Mar 9 11:14:53 UTC 2013
Hello Joel,
I briefly look at the cancellation sequence but it seemed to be quite
complex. There is also a POSIX requirement that we don't meet at the
moment:
http://pubs.opengroup.org/onlinepubs/7908799/xsh/pthread_cancel.html
"The cancellation processing in the target thread runs asynchronously
with respect to the calling thread returning from /pthread_cancel()/. "
There is also a problem in pthread_cleanup_push(). It allocates memory
from the workspace and fails silently in case this is not possible.
POSIX allows this:
http://pubs.opengroup.org/onlinepubs/7908799/xsh/pthread_cleanup_pop.html
"These functions may be implemented as macros and will appear as
statements and in pairs within the same lexical scope (that is, the
/pthread_cleanup_push()/ macro may be thought to expand to a token list
whose first token is *`{'* with /pthread_cleanup_pop()/ expanding to a
token list whose last token is the corresponding *`}'*. "
So it is possible to place the control structure on the thread stack.
On 08/03/13 20:23, Joel Sherrill wrote:
> Hi
> Sebastian mentioned this failure to me privately and I have taken a first
> look at it.
> My impression is that the cancellation request is doing some thread exit
> work and then the thread calls pthread_exit() and does it again. The
> second time, it faults dereferencing a NULL pointer.
> I will think on it but a fix is likely not too hard. I just want to
> understand
> the flow before I insert a NULL pointer check.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
