[PATCH 2/2] [cpukit/POSIX] Renamed POSIX signal functions to match style of the other POSIX related functions
Andreas Heinig
andreas.heinig at cs.tu-dortmund.de
Wed Mar 20 06:43:57 UTC 2013
On Tuesday 19 March 2013 09:21:35 Joel Sherrill wrote:
> + Your tree is NOT up to date. It has ChangeLog files in it.
True,
> + You did a blind search and replace since it changed ChangeLog
> entries before your change was made.
That is correct. However, I accidentally added the ChangeLog to the patch
> Now to see if I can understand what you were trying to
> do specifically. Can you give a very simple summary with
> details. Like "renamed X to Y". "Changed include from X to
> Y after renaming file." etc. The patch appears to be the
> result of a global search and replace and it would be
> easier to review if we knew what that was.
Ok, simply speaking: I had found a warning in the file
rtems/cpukit/sapi/src/posixapi.c. Here, the compiler complained about nested
external definition of _POSIX_signals_Manager_Initialization in function
_POSIX_API_Initialize.
After fixing the warning and having a closer look on _POSIX_API_Initialize, I
saw this:
64 _POSIX_signals_Manager_Initialization();
65 _POSIX_Threads_Manager_initialization();
66 _POSIX_Condition_variables_Manager_initialization();
67 _POSIX_Key_Manager_initialization();
68 _POSIX_Mutex_Manager_initialization();
69 _POSIX_Message_queue_Manager_initialization();
70 _POSIX_Semaphore_Manager_initialization();
71 _POSIX_Timer_Manager_initialization();
72 _POSIX_Barrier_Manager_initialization();
73 _POSIX_RWLock_Manager_initialization();
74 _POSIX_Spinlock_Manager_initialization();
Compared to all the other initialization routines, the Signal Manager has
different capitalization. Hence, I changed 's'ignals to 'S'ignals and
'I'nitialization to 'i'nitialization.
And due to the fact that the whole POSIX signal subsystem uses the "wrong"
prefix _POSIX_signals_, I have made a global search and replace to change it
to _POSIX_Signals_.
Here is the command:
find . ! -path "*/.svn*" ! -path "*/.git*" -type f \
-exec sed -e"s/_POSIX_signals/_POSIX_Signals/g" -i
Regards,
Andreas
