Changes in rtems-testing to run pc386 smp tests
Sree Harsha Konduri sreehars at buffalo.edu
Wed May 29 00:39:51 UTC 2013
Hello,
The following changes are to be made to the pc386 script in rtems-testing
in order to run pc386 SMP tests in qemu.
 > $RTEMS_TESTING/sim-scripts/pc386.in needs to be changed as follows
-cpu 486 needs to be changed to core2duo and also a new option -smp
<number_of_cores> needs to be added and
then make to regenerate the pc386 script.
Then running $RTEMS_TESTING/sim-scripts/pc386 -i <filepath> will run the
scripts.
Thanks,
Sree harsha Konduri
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130528/cdf7a5f4/attachment.html>
