Changes in rtems-testing to run pc386 smp tests
Joel Sherrill Joel.Sherrill at OARcorp.com
Wed May 29 03:55:02 UTC 2013
I am still in a car riding home from a long birthday weekend road trip.. But I have been thinking it would make sense to add a command line option for number of cores. If a simulator supports it, then it can turn on the appropriate options. This would be similar to how coverage and graphics can be ignored when a simulator doesn't support it.
Sree Harsha Konduri <sreehars at buffalo.edu> wrote:
Hello,
The following changes are to be made to the pc386 script in rtems-testing in order to run pc386 SMP tests in qemu.
 > $RTEMS_TESTING/sim-scripts/pc386.in<http://pc386.in> needs to be changed as follows
-cpu 486 needs to be changed to core2duo and also a new option -smp <number_of_cores> needs to be added and
then make to regenerate the pc386 script.
Then running $RTEMS_TESTING/sim-scripts/pc386 -i <filepath> will run the scripts.
Thanks,
Sree harsha Konduri
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130528/153b51cb/attachment-0001.html>
