I think the use of _Objects_Name_to_id_u32 should be
calling rtems_task_ident.
On 5/29/2013 10:31 AM, Sebastian Huber wrote:
> diff --git a/testsuites/sptests/spsimplesched02/init.c b/testsuites/sptests/spsimplesched02/init.c
> index 8b053b6..d4faa7a 100644
> --- a/testsuites/sptests/spsimplesched02/init.c
> +++ b/testsuites/sptests/spsimplesched02/init.c
> @@ -21,6 +21,7 @@ void ObtainRelease(bool suspendIdle);
> * Keep the names and IDs in global variables so another task can use them.
> +rtems_id Idle_id;
> rtems_id Task_id[ 3 ]; /* array of task ids */
> rtems_name Task_name[ 3 ]; /* array of task names */
> rtems_name Semaphore_name[ 2 ];
> @@ -48,7 +49,7 @@ void ObtainRelease( bool suspendIdle )
> if (suspendIdle) {
> puts( "INIT - Suspend Idle Task");
> - status = rtems_task_suspend( _Thread_Idle->Object.id );
> + status = rtems_task_suspend( Idle_id );
> directive_failed( status, "rtems_task_suspend idle" );
> @@ -62,7 +63,7 @@ void ObtainRelease( bool suspendIdle )
> if (suspendIdle) {
> puts( "INIT - Resume Idle Task");
> - status = rtems_task_resume( _Thread_Idle->Object.id );
> + status = rtems_task_resume( Idle_id );
> directive_failed( status, "rtems_task_resume idle" );
> @@ -75,6 +76,14 @@ rtems_task Init(
> puts( "\n\n*** SIMPLE SCHEDULER 02 TEST ***" );
> + status = _Objects_Name_to_id_u32(
> + &_Thread_Internal_information,
> + rtems_build_name( 'I', 'D', 'L', 'E' ),
> + RTEMS_SEARCH_LOCAL_NODE,
> + &Idle_id
> + rtems_test_assert( status == RTEMS_SUCCESSFUL );
> * Create the semaphore. Then obtain and release the
> * semaphore with no other tasks running.
