[PATCH 2/4] score: Remove idle field of Per_CPU_Control
Wed May 29 19:35:50 UTC 2013
On 29/05/13 21:14, Joel Sherrill wrote:
> I think the use of _Objects_Name_to_id_u32 should be
> calling rtems_task_ident.
The problem is that the idle threads are not RTEMS tasks.  You cannot
find them with rtems_task_ident().
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
