[rtems commit] bsps/arm: Add SMP support
Fri May 31 13:31:53 UTC 2013
Just a note that I added an argument to the sim-scripts
framework for number of cores.  I didn't do more than
check that it appeared to work.
It would be appreciated if you could follow what I did
in pc386.in and make similar changes to the realview
support file. Then we will know if I got it right.
FWIW This pretty much covers the set of targets I expected
would have SMP support anytime soon. The MIPS and
SPARC64 would be the ones I think are feasible.
--joel
On 5/31/2013 8:15 AM, Sebastian Huber wrote:
> Module:    rtems
> Branch:    master
> Commit:    db42c079a0479c17add94e5fb5fb89db1dfa6799
> Changeset: http://git.rtems.org/rtems/commit/?id=db42c079a0479c17add94e5fb5fb89db1dfa6799
> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date:      Fri May 31 13:59:47 2013 +0200
>   c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am   |    7 ++
>   c/src/lib/libbsp/arm/realview-pbx-a9/README        |    2 +
>   c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac  |    3 +
>   c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h |    6 ++
>   c/src/lib/libbsp/arm/realview-pbx-a9/include/irq.h |    4 -
>   .../make/custom/realview_pbx_a9_qemu_smp.cfg       |    1 +
>   c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am |    4 +
>   .../arm/realview-pbx-a9/startup/bspstarthooks.c    |   27 ++++--
>   .../{linkcmds => linkcmds.realview_pbx_a9_qemu}    |    0
>   ...{linkcmds => linkcmds.realview_pbx_a9_qemu_smp} |    2 +
>   c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c     |   71 ++++++++++++++++
>   c/src/lib/libbsp/arm/shared/arm-gic-irq.c          |   61 ++++++--------
>   .../libbsp/arm/shared/include/arm-a9mpcore-regs.h  |   16 ++++
>   .../libbsp/arm/shared/include/arm-a9mpcore-start.h |   88 ++++++++++++++++++++
>   .../lib/libbsp/arm/shared/include/arm-cp15-start.h |    6 ++
>   c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h  |   33 +++++++-
>   c/src/lib/libbsp/arm/shared/start/start.S          |   33 +++++++
>   c/src/lib/libbsp/arm/shared/startup/linkcmds.base  |    8 ++
>   c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am       |    7 ++
>   c/src/lib/libbsp/arm/xilinx-zynq/configure.ac      |    3 +
>   c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h     |    6 ++
>   c/src/lib/libbsp/arm/xilinx-zynq/include/irq.h     |    4 -
>   .../make/custom/xilinx_zynq_a9_qemu_smp.cfg        |    1 +
>   c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am     |    4 +
>   .../libbsp/arm/xilinx-zynq/startup/bspstarthooks.c |   27 ++++--
>   .../{linkcmds => linkcmds.xilinx_zynq_a9_qemu}     |    0
>   .../startup/linkcmds.xilinx_zynq_a9_qemu_smp}      |    2 +
>   c/src/lib/libcpu/arm/shared/include/arm-cp15.h     |   57 +++++++++++++
>   28 files changed, 418 insertions(+), 65 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
> index d8589a3..9410a30 100644
> --- a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
> +++ b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
> @@ -35,6 +35,7 @@ include_bsp_HEADERS += ../../shared/tod.h
>   include_bsp_HEADERS += ../shared/include/start.h
>   include_bsp_HEADERS += ../shared/include/arm-a9mpcore-irq.h
>   include_bsp_HEADERS += ../shared/include/arm-a9mpcore-regs.h
> +include_bsp_HEADERS += ../shared/include/arm-a9mpcore-start.h
>   include_bsp_HEADERS += ../shared/include/arm-cp15-start.h
>   include_bsp_HEADERS += ../shared/include/arm-gic.h
>   include_bsp_HEADERS += ../shared/include/arm-gic-irq.h
> @@ -59,6 +60,8 @@ project_lib_DATA = start.$(OBJEXT)
>   project_lib_DATA += startup/linkcmds
>   EXTRA_DIST =
> +EXTRA_DIST += startup/linkcmds.realview_pbx_a9_qemu
> +EXTRA_DIST += startup/linkcmds.realview_pbx_a9_qemu_smp
>   #                  LibBSP                                                     #
> @@ -121,6 +124,10 @@ libbsp_a_CPPFLAGS += -I$(srcdir)/../../../libcpu/arm/shared/include
>   # Start hooks
>   libbsp_a_SOURCES += startup/bspstarthooks.c
> +if HAS_SMP
> +libbsp_a_SOURCES += ../shared/arm-a9mpcore-smp.c
> +endif
>   #                  Special Rules                                              #
> diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/README b/c/src/lib/libbsp/arm/realview-pbx-a9/README
> index 8fdfdc4..a4e6ac1 100644
> --- a/c/src/lib/libbsp/arm/realview-pbx-a9/README
> +++ b/c/src/lib/libbsp/arm/realview-pbx-a9/README
> @@ -11,3 +11,5 @@ make install
>   export PATH="$PATH:/opt/qemu/bin"
>   qemu-system-arm -S -s -no-reboot -net none -nographic -M realview-pbx-a9 -m 256M -kernel ticker.exe
> +qemu-system-arm -S -s -no-reboot -net none -nographic -smp 2 -icount auto -M realview-pbx-a9 -m 256M -kernel ticker.exe
> diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac b/c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac
> index 4052dcc..61d7a2a 100644
> --- a/c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac
> +++ b/c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac
> @@ -33,6 +33,9 @@ RTEMS_BSPOPTS_HELP([CLOCK_DRIVER_USE_FAST_IDLE],
>   occurs while the IDLE thread is executing.  This can significantly reduce
>   simulation times.])
> +RTEMS_CHECK_SMP
> +AM_CONDITIONAL(HAS_SMP,[test "$rtems_cv_HAS_SMP" = "yes"])
>   RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
>   RTEMS_BSP_LINKCMDS
> diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h b/c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h
> index 41b714b..c25c9f6 100644
> --- a/c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h
> +++ b/c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h
> @@ -31,8 +31,14 @@
>   extern "C" {
>   #endif /* __cplusplus */
> +#define BSP_ARM_A9MPCORE_SCU_BASE 0x1f000000
> +#define BSP_ARM_GIC_CPUIF_BASE 0x1f000100
>   #define BSP_ARM_A9MPCORE_PT_BASE 0x1f000600
> +#define BSP_ARM_GIC_DIST_BASE 0x1f001000
>   typedef enum {
>     BSP_ARM_A9MPCORE_FATAL_CLOCK_IRQ_INSTALL,
>     BSP_ARM_A9MPCORE_FATAL_CLOCK_IRQ_REMOVE
> diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/include/irq.h b/c/src/lib/libbsp/arm/realview-pbx-a9/include/irq.h
> index 2651d6c..b065c36 100644
> --- a/c/src/lib/libbsp/arm/realview-pbx-a9/include/irq.h
> +++ b/c/src/lib/libbsp/arm/realview-pbx-a9/include/irq.h
> @@ -77,10 +77,6 @@ extern "C" {
>   #define BSP_INTERRUPT_VECTOR_MIN 0
>   #define BSP_INTERRUPT_VECTOR_MAX 89
> -#define BSP_ARM_GIC_CPUIF_BASE 0x1f000100
> -#define BSP_ARM_GIC_DIST_BASE 0x1f001000
>   #ifdef __cplusplus
> diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu_smp.cfg b/c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu_smp.cfg
> new file mode 100644
> index 0000000..fd51a18
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu_smp.cfg
> @@ -0,0 +1 @@
> +include $(RTEMS_ROOT)/make/custom/realview_pbx_a9_qemu.cfg
> diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am b/c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am
> index b153c8c..56e4ac8 100644
> --- a/c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am
> +++ b/c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am
> @@ -94,6 +94,10 @@ $(PROJECT_INCLUDE)/bsp/arm-a9mpcore-regs.h: ../shared/include/arm-a9mpcore-regs.
>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/arm-a9mpcore-regs.h
>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/arm-a9mpcore-regs.h
> +$(PROJECT_INCLUDE)/bsp/arm-a9mpcore-start.h: ../shared/include/arm-a9mpcore-start.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/arm-a9mpcore-start.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/arm-a9mpcore-start.h
>   $(PROJECT_INCLUDE)/bsp/arm-cp15-start.h: ../shared/include/arm-cp15-start.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/arm-cp15-start.h
>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/arm-cp15-start.h
> diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c b/c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c
> index 48e174a..93ebe20 100644
> --- a/c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c
> +++ b/c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c
> @@ -15,12 +15,14 @@
>   #include <bsp.h>
>   #include <bsp/start.h>
>   #include <bsp/arm-cp15-start.h>
> +#include <bsp/arm-a9mpcore-start.h>
>   #include <bsp/linker-symbols.h>
> -BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
> -  /* Do nothing */
> +#ifdef RTEMS_SMP
> +  #define MMU_DATA_READ_WRITE ARMV7_MMU_DATA_READ_WRITE_SHAREABLE
> +#else
> +  #define MMU_DATA_READ_WRITE ARMV7_MMU_DATA_READ_WRITE_CACHED
> +#endif
>   BSP_START_DATA_SECTION static const arm_cp15_start_section_config
>   rvpbxa9_mmu_config_table[] = {
> @@ -31,7 +33,7 @@ rvpbxa9_mmu_config_table[] = {
>       .begin = (uint32_t) bsp_section_fast_data_begin,
>       .end = (uint32_t) bsp_section_fast_data_end,
> -    .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
> +    .flags = MMU_DATA_READ_WRITE
>       .begin = (uint32_t) bsp_section_start_begin,
>       .end = (uint32_t) bsp_section_start_end,
> @@ -39,7 +41,7 @@ rvpbxa9_mmu_config_table[] = {
>       .begin = (uint32_t) bsp_section_vector_begin,
>       .end = (uint32_t) bsp_section_vector_end,
>       .begin = (uint32_t) bsp_section_text_begin,
>       .end = (uint32_t) bsp_section_text_end,
> @@ -51,19 +53,19 @@ rvpbxa9_mmu_config_table[] = {
>       .begin = (uint32_t) bsp_section_data_begin,
>       .end = (uint32_t) bsp_section_data_end,
>       .begin = (uint32_t) bsp_section_bss_begin,
>       .end = (uint32_t) bsp_section_bss_end,
>       .begin = (uint32_t) bsp_section_work_begin,
>       .end = (uint32_t) bsp_section_work_end,
>       .begin = (uint32_t) bsp_section_stack_begin,
>       .end = (uint32_t) bsp_section_stack_end,
>       .begin = 0x10000000U,
>       .end = 0x10020000U,
> @@ -91,6 +93,11 @@ BSP_START_TEXT_SECTION static void setup_mmu_and_cache(void)
> +BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
> +  arm_a9mpcore_start_hook_0();
>   BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
>     bsp_start_copy_sections();
> diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds b/c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds.realview_pbx_a9_qemu
> similarity index 100%
> copy from c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds
> copy to c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds.realview_pbx_a9_qemu
> diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds b/c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds.realview_pbx_a9_qemu_smp
> similarity index 92%
> copy to c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds.realview_pbx_a9_qemu_smp
> index 0b5e3e0..d76dd2e 100644
> --- a/c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds
> +++ b/c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds.realview_pbx_a9_qemu_smp
> @@ -28,4 +28,6 @@ bsp_vector_table_in_start_section = 1;
>   bsp_translation_table_base = ORIGIN (RAM_MMU);
> +bsp_processor_count = DEFINED (bsp_processor_count) ? bsp_processor_count : 8;
>   INCLUDE linkcmds.armv4
> diff --git a/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c b/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c
> index 0000000..b94bcec
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c
> @@ -0,0 +1,71 @@
> + * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <info at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#include <assert.h>
> +#include <rtems/bspsmp.h>
> +#include <libcpu/arm-cp15.h>
> +#include <bsp/irq.h>
> +int bsp_smp_processor_id(void)
> +  return (int) arm_cortex_a9_get_multiprocessor_cpu_id();
> +static void ipi_handler(void *arg)
> +  rtems_smp_process_interrupt();
> +uint32_t bsp_smp_initialize(uint32_t configured_cpu_count)
> +  rtems_status_code sc;
> +  uint32_t max_cpu_count = arm_gic_irq_processor_count();
> +  uint32_t used_cpu_count = configured_cpu_count < max_cpu_count ?
> +    configured_cpu_count : max_cpu_count;
> +  sc = rtems_interrupt_handler_install(
> +    ARM_GIC_IRQ_SGI_0,
> +    "IPI",
> +    RTEMS_INTERRUPT_UNIQUE,
> +    ipi_handler,
> +    NULL
> +  assert(sc == RTEMS_SUCCESSFUL);
> +  return used_cpu_count;
> +void bsp_smp_broadcast_interrupt(void)
> +   * FIXME: This broadcasts the interrupt also to processors not used by RTEMS.
> +  rtems_status_code sc = arm_gic_irq_generate_software_irq(
> +    ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_EXCEPT_SELF,
> +    0xff
> +void bsp_smp_interrupt_cpu(int cpu)
> +    ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_IN_LIST,
> +    (uint8_t) (1U << cpu)
> diff --git a/c/src/lib/libbsp/arm/shared/arm-gic-irq.c b/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
> index 84d66aa..ed2d389 100644
> --- a/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
> +++ b/c/src/lib/libbsp/arm/shared/arm-gic-irq.c
> @@ -18,14 +18,12 @@
> -#include <bsp.h>
>   #include <bsp/irq-generic.h>
> +#include <bsp/start.h>
>   #define GIC_CPUIF ((volatile gic_cpuif *) BSP_ARM_GIC_CPUIF_BASE)
> -#define GIC_DIST ((volatile gic_dist *) BSP_ARM_GIC_DIST_BASE)
>   #define PRIORITY_DEFAULT 128
>   void bsp_interrupt_dispatch(void)
> @@ -51,7 +49,7 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>     rtems_status_code sc = RTEMS_SUCCESSFUL;
>     if (bsp_interrupt_is_valid_vector(vector)) {
> -    volatile gic_dist *dist = GIC_DIST;
> +    volatile gic_dist *dist = ARM_GIC_DIST;
>       gic_id_enable(dist, vector);
>     } else {
> @@ -66,7 +64,7 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
>       gic_id_disable(dist, vector);
>     } else {
> @@ -89,10 +87,15 @@ static inline uint32_t get_id_count(volatile gic_dist *dist)
>   rtems_status_code bsp_interrupt_facility_initialize(void)
>     volatile gic_cpuif *cpuif = GIC_CPUIF;
>     uint32_t id_count = get_id_count(dist);
>     uint32_t id;
> +  arm_cp15_set_exception_handler(
> +    ARM_EXCEPTION_IRQ,
> +    _ARMV4_Exception_interrupt
>     for (id = 0; id < id_count; ++id) {
>       gic_id_set_priority(dist, id, PRIORITY_DEFAULT);
> @@ -107,14 +110,25 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
>     dist->icddcr = GIC_DIST_ICDDCR_ENABLE;
> -  arm_cp15_set_exception_handler(
> -    ARM_EXCEPTION_IRQ,
> -    _ARMV4_Exception_interrupt
>     return RTEMS_SUCCESSFUL;
> +#ifdef RTEMS_SMP
> +BSP_START_TEXT_SECTION void arm_gic_irq_initialize_secondary_cpu(void)
> +  volatile gic_cpuif *cpuif = GIC_CPUIF;
> +  while ((dist->icddcr & GIC_DIST_ICDDCR_ENABLE) == 0) {
> +    /* Wait */
> +  cpuif->iccpmr = GIC_CPUIF_ICCPMR_PRIORITY(0xff);
> +  cpuif->iccbpr = GIC_CPUIF_ICCBPR_BINARY_POINT(0x0);
> +  cpuif->iccicr = GIC_CPUIF_ICCICR_ENABLE;
> +#endif
>   rtems_status_code arm_gic_irq_set_priority(
>     rtems_vector_number vector,
>     uint8_t priority
> @@ -123,7 +137,7 @@ rtems_status_code arm_gic_irq_set_priority(
>       gic_id_set_priority(dist, vector, priority);
>     } else {
> @@ -141,7 +155,7 @@ rtems_status_code arm_gic_irq_get_priority(
>       *priority = gic_id_get_priority(dist, vector);
>     } else {
> @@ -150,24 +164,3 @@ rtems_status_code arm_gic_irq_get_priority(
>     return sc;
> -rtems_status_code arm_gic_irq_generate_software_irq(
> -  rtems_vector_number vector,
> -  arm_gic_irq_software_irq_target_filter filter,
> -  uint8_t targets
> -  rtems_status_code sc = RTEMS_SUCCESSFUL;
> -  if (vector < 16) {
> -    dist->icdsgir = GIC_DIST_ICDSGIR_TARGET_LIST_FILTER(filter)
> -      | GIC_DIST_ICDSGIR_CPU_TARGET_LIST(targets)
> -      | GIC_DIST_ICDSGIR_SGIINTID(vector);
> -  } else {
> -    sc = RTEMS_INVALID_ID;
> -  return sc;
> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h
> index 7d8f637..dc7fd75 100644
> --- a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h
> +++ b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h
> @@ -19,7 +19,23 @@
>   typedef struct {
>     uint32_t ctrl;
> +#define A9MPCORE_SCU_CTRL_SCU_EN BSP_BIT32(0)
> +#define A9MPCORE_SCU_CTRL_ADDR_FLT_EN BSP_BIT32(1)
> +#define A9MPCORE_SCU_CTRL_RAM_PAR_EN BSP_BIT32(2)
> +#define A9MPCORE_SCU_CTRL_SCU_SPEC_LINE_FILL_EN BSP_BIT32(3)
> +#define A9MPCORE_SCU_CTRL_FORCE_PORT_0_EN BSP_BIT32(4)
> +#define A9MPCORE_SCU_CTRL_SCU_STANDBY_EN BSP_BIT32(5)
> +#define A9MPCORE_SCU_CTRL_IC_STANDBY_EN BSP_BIT32(6)
>     uint32_t cfg;
> +#define A9MPCORE_SCU_CFG_CPU_COUNT(val) BSP_FLD32(val, 0, 1)
> +#define A9MPCORE_SCU_CFG_CPU_COUNT_GET(reg) BSP_FLD32GET(reg, 0, 1)
> +#define A9MPCORE_SCU_CFG_CPU_COUNT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 1)
> +#define A9MPCORE_SCU_CFG_SMP_MODE(val) BSP_FLD32(val, 4, 7)
> +#define A9MPCORE_SCU_CFG_SMP_MODE_GET(reg) BSP_FLD32GET(reg, 4, 7)
> +#define A9MPCORE_SCU_CFG_SMP_MODE_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
> +#define A9MPCORE_SCU_CFG_TAG_RAM_SIZE(val) BSP_FLD32(val, 8, 15)
> +#define A9MPCORE_SCU_CFG_TAG_RAM_SIZE_GET(reg) BSP_FLD32GET(reg, 8, 15)
> +#define A9MPCORE_SCU_CFG_TAG_RAM_SIZE_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
>     uint32_t pwrst;
>     uint32_t invss;
>     uint32_t reserved_10[12];
> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
> index 0000000..b42c549
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
> @@ -0,0 +1,88 @@
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> +#ifndef LIBBSP_ARM_SHARED_ARM_A9MPCORE_START_H
> +#define LIBBSP_ARM_SHARED_ARM_A9MPCORE_START_H
> +#include <bsp.h>
> +#include <bsp/arm-a9mpcore-regs.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +BSP_START_TEXT_SECTION static inline uint32_t
> +arm_cp15_get_auxiliary_control(void);
> +BSP_START_TEXT_SECTION static inline void
> +arm_cp15_set_auxiliary_control(uint32_t val);
> +BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_hook_0(void)
> +#ifdef RTEMS_SMP
> +  volatile a9mpcore_scu *scu = (volatile a9mpcore_scu *) BSP_ARM_A9MPCORE_SCU_BASE;
> +  uint32_t cpu_id;
> +  uint32_t actlr;
> +  /* Enable Snoop Control Unit (SCU) */
> +  scu->ctrl |= A9MPCORE_SCU_CTRL_SCU_EN;
> +  /* Enable cache coherency support for this processor */
> +  actlr = arm_cp15_get_auxiliary_control();
> +  actlr |= ARM_CORTEX_A9_ACTL_SMP;
> +  arm_cp15_set_auxiliary_control(actlr);
> +  cpu_id = arm_cortex_a9_get_multiprocessor_cpu_id();
> +  if (cpu_id != 0) {
> +    if (cpu_id < rtems_configuration_get_maximum_processors()) {
> +      uint32_t ctrl;
> +      arm_gic_irq_initialize_secondary_cpu();
> +      ctrl = arm_cp15_start_setup_mmu_and_cache(
> +        0,
> +        ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z
> +      arm_cp15_set_domain_access_control(
> +        ARM_CP15_DAC_DOMAIN(ARM_MMU_DEFAULT_CLIENT_DOMAIN, ARM_CP15_DAC_CLIENT)
> +      /* FIXME: Sharing the translation table between processors is brittle */
> +      arm_cp15_set_translation_table_base((uint32_t *) bsp_translation_table_base);
> +      ctrl |= ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M;
> +      arm_cp15_set_control(ctrl);
> +      rtems_smp_secondary_cpu_initialize();
> +    } else {
> +      /* FIXME: Shutdown processor */
> +      while (1) {
> +        __asm__ volatile ("wfi");
> +#endif
> +#ifdef __cplusplus
> +#endif /* LIBBSP_ARM_SHARED_ARM_A9MPCORE_START_H */
> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h b/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
> index 6fb8226..11efbcd 100644
> --- a/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
> +++ b/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
> @@ -41,6 +41,12 @@ arm_cp15_cache_invalidate(void);
>   arm_cp15_tlb_invalidate(void);
> +arm_cp15_get_multiprocessor_affinity(void);
> +arm_cortex_a9_get_multiprocessor_cpu_id(void);
>   typedef struct {
>     uint32_t begin;
>     uint32_t end;
> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h b/c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h
> index c45d354..5c152a1 100644
> --- a/c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h
> +++ b/c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h
> @@ -15,7 +15,8 @@
>   #ifndef LIBBSP_ARM_SHARED_ARM_GIC_IRQ_H
>   #define LIBBSP_ARM_SHARED_ARM_GIC_IRQ_H
> -#include <rtems.h>
> +#include <bsp.h>
> +#include <bsp/arm-gic.h>
>   #ifdef __cplusplus
>   extern "C" {
> @@ -37,6 +38,8 @@ extern "C" {
>   #define ARM_GIC_IRQ_SGI_14 14
>   #define ARM_GIC_IRQ_SGI_15 15
> +#define ARM_GIC_DIST ((volatile gic_dist *) BSP_ARM_GIC_DIST_BASE)
>     uint8_t priority
> @@ -53,11 +56,35 @@ typedef enum {
>     ARM_GIC_IRQ_SOFTWARE_IRQ_TO_SELF
>   } arm_gic_irq_software_irq_target_filter;
> +static inline rtems_status_code arm_gic_irq_generate_software_irq(
>     uint8_t targets
> +  rtems_status_code sc = RTEMS_SUCCESSFUL;
> +  if (vector <= ARM_GIC_IRQ_SGI_15) {
> +    dist->icdsgir = GIC_DIST_ICDSGIR_TARGET_LIST_FILTER(filter)
> +      | GIC_DIST_ICDSGIR_CPU_TARGET_LIST(targets)
> +      | GIC_DIST_ICDSGIR_SGIINTID(vector);
> +  } else {
> +    sc = RTEMS_INVALID_ID;
> +  return sc;
> +static inline uint32_t arm_gic_irq_processor_count(void)
> +  return GIC_DIST_ICDICTR_CPU_NUMBER_GET(dist->icdictr) + 1;
> +void arm_gic_irq_initialize_secondary_cpu(void);
>   #ifdef __cplusplus
> diff --git a/c/src/lib/libbsp/arm/shared/start/start.S b/c/src/lib/libbsp/arm/shared/start/start.S
> index e79a5fc..7b59ab4 100644
> --- a/c/src/lib/libbsp/arm/shared/start/start.S
> +++ b/c/src/lib/libbsp/arm/shared/start/start.S
> @@ -31,6 +31,14 @@
>          .extern boot_card
>          .extern bsp_start_hook_0
>          .extern bsp_start_hook_1
> +       .extern bsp_stack_irq_end
> +       .extern bsp_stack_fiq_end
> +       .extern bsp_stack_abt_end
> +       .extern bsp_stack_und_end
> +       .extern bsp_stack_svc_end
> +#ifdef RTEMS_SMP
> +       .extern bsp_stack_all_size
> +#endif
>          .extern _ARMV4_Exception_undef_default
>          .extern _ARMV4_Exception_swi_default
>          .extern _ARMV4_Exception_data_abort_default
> @@ -119,6 +127,16 @@ _start:
>           * loader.
> +#ifdef RTEMS_SMP
> +       /* Read MPIDR */
> +       mrc     p15, 0, r0, c0, c0, 5
> +       /* Calculate stack offset */
> +       and     r0, #0xff
> +       ldr     r1, =bsp_stack_all_size
> +       mul     r1, r0
> +#endif
>           * Set SVC mode, disable interrupts and enable ARM instructions.
> @@ -131,26 +149,41 @@ _start:
>          mov     r0, #(ARM_PSR_M_IRQ | ARM_PSR_I | ARM_PSR_F)
>          msr     cpsr, r0
>          ldr     sp, =bsp_stack_irq_end
> +#ifdef RTEMS_SMP
> +       add     sp, r1
> +#endif
>          /* Enter FIQ mode and set up the FIQ stack pointer */
>          mov     r0, #(ARM_PSR_M_FIQ | ARM_PSR_I | ARM_PSR_F)
>          msr     cpsr, r0
>          ldr     sp, =bsp_stack_fiq_end
> +#ifdef RTEMS_SMP
> +       add     sp, r1
> +#endif
>          /* Enter ABT mode and set up the ABT stack pointer */
>          mov     r0, #(ARM_PSR_M_ABT | ARM_PSR_I | ARM_PSR_F)
>          msr     cpsr, r0
>          ldr     sp, =bsp_stack_abt_end
> +#ifdef RTEMS_SMP
> +       add     sp, r1
> +#endif
>          /* Enter UND mode and set up the UND stack pointer */
>          mov     r0, #(ARM_PSR_M_UND | ARM_PSR_I | ARM_PSR_F)
>          msr     cpsr, r0
>          ldr     sp, =bsp_stack_und_end
> +#ifdef RTEMS_SMP
> +       add     sp, r1
> +#endif
>          /* Enter SVC mode and set up the SVC stack pointer */
>          mov     r0, #(ARM_PSR_M_SVC | ARM_PSR_I | ARM_PSR_F)
>          msr     cpsr, r0
>          ldr     sp, =bsp_stack_svc_end
> +#ifdef RTEMS_SMP
> +       add     sp, r1
> +#endif
>          /* Stay in SVC mode */
> diff --git a/c/src/lib/libbsp/arm/shared/startup/linkcmds.base b/c/src/lib/libbsp/arm/shared/startup/linkcmds.base
> index 27f5acb..d1a73d0 100644
> --- a/c/src/lib/libbsp/arm/shared/startup/linkcmds.base
> +++ b/c/src/lib/libbsp/arm/shared/startup/linkcmds.base
> @@ -56,6 +56,10 @@ bsp_stack_und_size = ALIGN (bsp_stack_und_size, bsp_stack_align);
>   bsp_stack_main_size = DEFINED (bsp_stack_main_size) ? bsp_stack_main_size : 0;
>   bsp_stack_main_size = ALIGN (bsp_stack_main_size, bsp_stack_align);
> +bsp_stack_all_size = bsp_stack_abt_size + bsp_stack_fiq_size + bsp_stack_irq_size + bsp_stack_svc_size + bsp_stack_und_size + bsp_stack_main_size;
> +bsp_processor_count = DEFINED (bsp_processor_count) ? bsp_processor_count : 1;
>   MEMORY {
>          UNEXPECTED_SECTIONS : ORIGIN = 0xffffffff, LENGTH = 0
> @@ -324,6 +328,10 @@ SECTIONS {
>                  . = . + bsp_stack_main_size;
>                  bsp_stack_main_end = .;
> +               bsp_stack_secondary_processors_begin = .;
> +               . = . + (bsp_processor_count - 1) * bsp_stack_all_size;
> +               bsp_stack_secondary_processors_end = .;
>                  *(.bsp_vector)
>                  bsp_section_vector_end = .;
> diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
> index ad42b2f..99ff1fb 100644
> --- a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
> +++ b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
>   EXTRA_DIST =
> +EXTRA_DIST += startup/linkcmds.xilinx_zynq_a9_qemu
> +EXTRA_DIST += startup/linkcmds.xilinx_zynq_a9_qemu_smp
>   #                  LibBSP                                                     #
>   # Start hooks
> +if HAS_SMP
> +endif
>   #                  Special Rules                                              #
> diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac b/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
> index fcb77be..c739f69 100644
> --- a/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
> +++ b/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
>   simulation times.])
> +RTEMS_CHECK_SMP
>   RTEMS_BSP_LINKCMDS
> diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h b/c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h
> index a0267d4..617aed3 100644
> --- a/c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h
> +++ b/c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h
> @@ -31,8 +31,14 @@
>   extern "C" {
> +#define BSP_ARM_A9MPCORE_SCU_BASE 0xf8f00000
> +#define BSP_ARM_GIC_CPUIF_BASE 0xf8f00100
>   #define BSP_ARM_A9MPCORE_PT_BASE 0xf8f00600
> +#define BSP_ARM_GIC_DIST_BASE 0xf8f01000
>   typedef enum {
> diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/include/irq.h b/c/src/lib/libbsp/arm/xilinx-zynq/include/irq.h
> index 9781768..824dd4e 100644
> --- a/c/src/lib/libbsp/arm/xilinx-zynq/include/irq.h
> +++ b/c/src/lib/libbsp/arm/xilinx-zynq/include/irq.h
> @@ -91,10 +91,6 @@ extern "C" {
>   #define BSP_INTERRUPT_VECTOR_MAX 92
> -#define BSP_ARM_GIC_CPUIF_BASE 0xf8f00100
> -#define BSP_ARM_GIC_DIST_BASE 0xf8f01000
>   #ifdef __cplusplus
> diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu_smp.cfg b/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu_smp.cfg
> index 0000000..2a0e35a
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu_smp.cfg
> @@ -0,0 +1 @@
> +include $(RTEMS_ROOT)/make/custom/xilinx_zynq_a9_qemu.cfg
> diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am b/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am
> index 40a1e61..5b94e31 100644
> --- a/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am
> +++ b/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am
> diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c b/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c
> index f9fceeb..32585fe 100644
> --- a/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c
> +++ b/c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c
> @@ -15,12 +15,14 @@
>   #include <bsp.h>
> -  /* Do nothing */
> +#ifdef RTEMS_SMP
> +#else
> +#endif
>   zynq_mmu_config_table[] = {
> @@ -31,7 +33,7 @@ zynq_mmu_config_table[] = {
> @@ -39,7 +41,7 @@ zynq_mmu_config_table[] = {
> @@ -51,19 +53,19 @@ zynq_mmu_config_table[] = {
>       .begin = 0xe0000000U,
>       .end = 0xe0200000U,
> diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds b/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu
> rename from c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds
> rename to c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu
> diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds b/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu_smp
> rename from c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds
> rename to c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu_smp
> +++ b/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu_smp
> diff --git a/c/src/lib/libcpu/arm/shared/include/arm-cp15.h b/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
> index ffb2cc6..6d7cf39 100644
> --- a/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
> +++ b/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
> @@ -842,6 +842,63 @@ static inline void arm_cp15_wait_for_interrupt(void)
> +static inline uint32_t arm_cp15_get_multiprocessor_affinity(void)
> +  ARM_SWITCH_REGISTERS;
> +  uint32_t mpidr;
> +    ARM_SWITCH_TO_ARM
> +         "mrc p15, 0, %[mpidr], c0, c0, 5\n"
> +    ARM_SWITCH_BACK
> +    : [mpidr] "=&r" (mpidr) ARM_SWITCH_ADDITIONAL_OUTPUT
> +  return mpidr & 0xff;
> +static inline uint32_t arm_cortex_a9_get_multiprocessor_cpu_id(void)
> +  return arm_cp15_get_multiprocessor_affinity() & 0xff;
> +#define ARM_CORTEX_A9_ACTL_FW (1U << 0)
> +#define ARM_CORTEX_A9_ACTL_L2_PREFETCH_HINT_ENABLE (1U << 1)
> +#define ARM_CORTEX_A9_ACTL_L1_PREFETCH_ENABLE (1U << 2)
> +#define ARM_CORTEX_A9_ACTL_WRITE_FULL_LINE_OF_ZEROS_MODE (1U << 3)
> +#define ARM_CORTEX_A9_ACTL_SMP (1U << 6)
> +#define ARM_CORTEX_A9_ACTL_EXCL (1U << 7)
> +#define ARM_CORTEX_A9_ACTL_ALLOC_IN_ONE_WAY (1U << 8)
> +#define ARM_CORTEX_A9_ACTL_PARITY_ON (1U << 9)
> +static inline uint32_t arm_cp15_get_auxiliary_control(void)
> +  uint32_t val;
> +    ARM_SWITCH_TO_ARM
> +    "mrc p15, 0, %[val], c1, c0, 1\n"
> +    ARM_SWITCH_BACK
> +    : [val] "=&r" (val) ARM_SWITCH_ADDITIONAL_OUTPUT
> +  return val;
> +static inline void arm_cp15_set_auxiliary_control(uint32_t val)
> +    ARM_SWITCH_TO_ARM
> +    "mcr p15, 0, %[val], c1, c0, 1\n"
> +    ARM_SWITCH_BACK
> +    : ARM_SWITCH_OUTPUT
> +    : [val] "r" (val)
>    * @brief Sets the @a section_flags for the address range [@a begin, @a end).
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
