[PATCH] RTEMS: Increase MSIZE from 128 to 256
Sebastian Huber
Fri Nov 1 11:44:52 UTC 2013
On 11/01/2013 12:17 AM, Joel Sherrill wrote:
> My original version of this change wrapped it in an RTEMS new stack macro.
Yes, but your original patch is not a huge help since you can simpley use
#define MSIZE 123
#include <sys/param.h>
#include <sys/mbuf.h>
Both ways are a bad hack and can lead to very hard to debug problems if
two modules work with mbufs of different sizes.
> Chris Johns<chrisj at rtems.org> wrote:
> On 1/11/2013 12:11 am, Sebastian Huber wrote:
>> >This change is necessary to support IPv6. It affects applications using
>> >the current network stack of RTEMS since this will half the mbuf count
>> >in the system.
> I am not sure about this change going into 4.11. If the new stack went
> in as well that is a different story.
> Because of the long time frame between 4.10 and 4.11 (yes some people
> have got married and had children), users are having to using 4.11.
> Can this sit out of the changes until 4.11 and then go in ?
Ok, we can wait for the 4.11 release.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
