NTP broadcast problems with RTEMS 4.10.2 and 4.11
Gedare Bloom
gedare at rtems.org
Fri Nov 1 14:01:35 UTC 2013
I generated a patch against the RTEMS head. Please double-check that
it works correctly (I did not try it out.) Hopefully Joel or someone
else knowledgeable about the networking stack / NTP will weigh in.
-Gedare
On Tue, Oct 29, 2013 at 8:40 PM, Jim Panetta <panetta at slac.stanford.edu> wrote:
> Hello,
> I've been having trouble with Network Time Protocol broadcasts under RTEMS
> 4.10.2 and 4.11 (HEAD). Non-broadcast works perfectly fine.
> For non-broadcast, my RTEMS host is configured with the address of the NTP
> server, and my NTP server is configured with:
> restrict 172.21.7.192 mask 255.255.255.192 nomodify notrap nopeer
> With this, I see the request/reply packets after the call to
> rtems_bsdnet_synchronize_ntp(0,0) and the time is synced correctly.
> For an NTP server setup as broadcast, the situation is different. With the
> server configuration line:
> broadcast 172.21.7.255 minpoll 4
> replacing the 'restrict' statement above and no server configured on the
> RTEMS
> host, I don't get sync. I do see the UDP packets on the RTEMS host every 16
> seconds, but the time is not adjusted on receipt.
> Tracing this down found a couple of things that needed changing:
> 1) the value of rtems_bsdnet_ntpserver_count is equal to 0 when no
> server is set, so the check for (rtems_bsdnet_ntpserver_count < 0)
> in rtems_bsdnet_get_ntp() is wrong. The check should be "<= 0".
> 2) Binding the listening socket port to 0 does not work. Packets
> appear on the interface, but the recvfrom in tryServer() never
> returns. Changing this to the well known NTP socket 123 allows the
> packets to be seen. (See NOTE below)
> 3) In tryServer(), an explicit check for NTP version 3 packets is made.
> If the NTP server is version 4, this check fails even though the
> packets seem to be the right shape.
> NOTE: Change 2 conflicts with the changes made to rtems_bsd_net.c by Eric
> Norum and Joel Sherril between 2008-09-23 and 2008-09-26. I could not find
> any mailing list traffic on this, other than one message from Daron Chabot
> on
> 2008-11-12 in reference to RTEMS 4.9.1:
> http://www.rtems.org/pipermail/rtems-users/2008-November/004455.html.
> With these changes both broadcast and non-broadcast seem to set the time
> correctly. The only caveat is that for the broadcast mode,
> rtems_bsdnet_get_ntp() blocks until it gets a packet (or until timeout after
> 5*80 seconds).
> Here is the full patch I have made to our local installation:
> bash-3.2$ diff rtems_bsdnet_ntp.c rtems_bsdnet_ntp.c.orig
> 143a144,146
>> /* Changed ntp packet version match from '3' to '3 or 4', since
> version 4 will still work
>> panetta at slac.stanford.edu 2013-02-22
> 145c148,149
> < ((packet.li_vn_mode & (0x7 << 3)) == (3 << 3)) &&
>> (((packet.li_vn_mode & (0x7 << 3)) == (3 << 3)) ||
>> ((packet.li_vn_mode & (0x7 << 3)) == (4 << 3))) &&
> 179c183
> < myAddr.sin_port = htons (0);
>> myAddr.sin_port = htons (123);
> 195c199
> < if (rtems_bsdnet_ntpserver_count < 0) {
>> if (rtems_bsdnet_ntpserver_count <= 0) {
> Prior to this being committed, Joel and/or Eric should probably weigh in.
> Thanks,
> --Jim Panetta panetta at slac.stanford.edu
> My opinions are mine...not DOE's...not SLAC's...mine.
> (except by random, unforseeable coincidences)
> panetta at slac.stanford.edu -- Save the whales! Free the mallocs!
> rtems-devel mailing list
> rtems-devel at rtems.org
