NTP broadcast problems with RTEMS 4.10.2 and 4.11
Gedare Bloom
gedare at rtems.org
Fri Nov 1 14:09:07 UTC 2013
Also, these seem like bug fixes to me. It might be worth opening a PR
on bugzilla [1] so we can track fixes back to 4.10.
-Gedare
On Fri, Nov 1, 2013 at 10:01 AM, Gedare Bloom <gedare at rtems.org> wrote:
> I generated a patch against the RTEMS head. Please double-check that
> it works correctly (I did not try it out.) Hopefully Joel or someone
> else knowledgeable about the networking stack / NTP will weigh in.
> -Gedare
> On Tue, Oct 29, 2013 at 8:40 PM, Jim Panetta <panetta at slac.stanford.edu> wrote:
>> Hello,
>> I've been having trouble with Network Time Protocol broadcasts under RTEMS
>> 4.10.2 and 4.11 (HEAD). Non-broadcast works perfectly fine.
>> For non-broadcast, my RTEMS host is configured with the address of the NTP
>> server, and my NTP server is configured with:
>> restrict 172.21.7.192 mask 255.255.255.192 nomodify notrap nopeer
>> With this, I see the request/reply packets after the call to
>> rtems_bsdnet_synchronize_ntp(0,0) and the time is synced correctly.
>> For an NTP server setup as broadcast, the situation is different. With the
>> server configuration line:
>> broadcast 172.21.7.255 minpoll 4
>> replacing the 'restrict' statement above and no server configured on the
>> RTEMS
>> host, I don't get sync. I do see the UDP packets on the RTEMS host every 16
>> seconds, but the time is not adjusted on receipt.
>> Tracing this down found a couple of things that needed changing:
>> 1) the value of rtems_bsdnet_ntpserver_count is equal to 0 when no
>> server is set, so the check for (rtems_bsdnet_ntpserver_count < 0)
>> in rtems_bsdnet_get_ntp() is wrong. The check should be "<= 0".
>> 2) Binding the listening socket port to 0 does not work. Packets
>> appear on the interface, but the recvfrom in tryServer() never
>> returns. Changing this to the well known NTP socket 123 allows the
>> packets to be seen. (See NOTE below)
>> 3) In tryServer(), an explicit check for NTP version 3 packets is made.
>> If the NTP server is version 4, this check fails even though the
>> packets seem to be the right shape.
>> NOTE: Change 2 conflicts with the changes made to rtems_bsd_net.c by Eric
>> Norum and Joel Sherril between 2008-09-23 and 2008-09-26. I could not find
>> any mailing list traffic on this, other than one message from Daron Chabot
>> on
>> 2008-11-12 in reference to RTEMS 4.9.1:
>> http://www.rtems.org/pipermail/rtems-users/2008-November/004455.html.
>> With these changes both broadcast and non-broadcast seem to set the time
>> correctly. The only caveat is that for the broadcast mode,
>> rtems_bsdnet_get_ntp() blocks until it gets a packet (or until timeout after
>> 5*80 seconds).
>> Here is the full patch I have made to our local installation:
>> bash-3.2$ diff rtems_bsdnet_ntp.c rtems_bsdnet_ntp.c.orig
>> 143a144,146
>>> /* Changed ntp packet version match from '3' to '3 or 4', since
>> version 4 will still work
>>> panetta at slac.stanford.edu 2013-02-22
>> 145c148,149
>> < ((packet.li_vn_mode & (0x7 << 3)) == (3 << 3)) &&
>>> (((packet.li_vn_mode & (0x7 << 3)) == (3 << 3)) ||
>>> ((packet.li_vn_mode & (0x7 << 3)) == (4 << 3))) &&
>> 179c183
>> < myAddr.sin_port = htons (0);
>>> myAddr.sin_port = htons (123);
>> 195c199
>> < if (rtems_bsdnet_ntpserver_count < 0) {
>>> if (rtems_bsdnet_ntpserver_count <= 0) {
>> Prior to this being committed, Joel and/or Eric should probably weigh in.
>> Thanks,
>> --Jim Panetta panetta at slac.stanford.edu
>> My opinions are mine...not DOE's...not SLAC's...mine.
>> (except by random, unforseeable coincidences)
>> panetta at slac.stanford.edu -- Save the whales! Free the mallocs!
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
