NTP broadcast problems with RTEMS 4.10.2 and 4.11
    Jim Panetta
    panetta at slac.stanford.edu
    Fri Nov  1 19:14:46 UTC 2013
Will do, Gedare.
   --Jim
On 11/01/2013 07:09 AM, Gedare Bloom wrote:
> Also, these seem like bug fixes to me. It might be worth opening a PR
> on bugzilla [1] so we can track fixes back to 4.10.
> -Gedare
> On Fri, Nov 1, 2013 at 10:01 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> I generated a patch against the RTEMS head. Please double-check that
>> it works correctly (I did not try it out.) Hopefully Joel or someone
>> else knowledgeable about the networking stack / NTP will weigh in.
>> -Gedare
>> On Tue, Oct 29, 2013 at 8:40 PM, Jim Panetta <panetta at slac.stanford.edu> wrote:
>>> Hello,
>>> I've been having trouble with Network Time Protocol broadcasts under RTEMS
>>> 4.10.2 and 4.11 (HEAD).  Non-broadcast works perfectly fine.
>>> For non-broadcast, my RTEMS host is configured with the address of the NTP
>>> server, and my NTP server is configured with:
>>> restrict 172.21.7.192 mask 255.255.255.192 nomodify notrap nopeer
>>> With this, I see the request/reply packets after the call to
>>> rtems_bsdnet_synchronize_ntp(0,0) and the time is synced correctly.
>>> For an NTP server setup as broadcast, the situation is different.  With the
>>> server configuration line:
>>> broadcast 172.21.7.255 minpoll 4
>>> replacing the 'restrict' statement above and no server configured on the
>>> RTEMS
>>> host, I don't get sync.  I do see the UDP packets on the RTEMS host every 16
>>> seconds, but the time is not adjusted on receipt.
>>> Tracing this down found a couple of things that needed changing:
>>> 1) the value of rtems_bsdnet_ntpserver_count is equal to 0 when no
>>>     server is set, so the check for (rtems_bsdnet_ntpserver_count < 0)
>>>     in rtems_bsdnet_get_ntp() is wrong.  The check should be "<= 0".
>>> 2) Binding the listening socket port to 0 does not work.  Packets
>>>     appear on the interface, but the recvfrom in tryServer() never
>>>     returns.  Changing this to the well known NTP socket 123 allows the
>>>     packets to be seen. (See NOTE below)
>>> 3) In tryServer(), an explicit check for NTP version 3 packets is made.
>>>     If the NTP server is version 4, this check fails even though the
>>>     packets seem to be the right shape.
>>> NOTE: Change 2 conflicts with the changes made to rtems_bsd_net.c by Eric
>>> Norum and Joel Sherril between 2008-09-23 and 2008-09-26.  I could not find
>>> any mailing list traffic on this, other than one message from Daron Chabot
>>> on
>>> 2008-11-12 in reference to RTEMS 4.9.1:
>>> http://www.rtems.org/pipermail/rtems-users/2008-November/004455.html.
>>> With these changes both broadcast and non-broadcast seem to set the time
>>> correctly.  The only caveat is that for the broadcast mode,
>>> rtems_bsdnet_get_ntp() blocks until it gets a packet (or until timeout after
>>> 5*80 seconds).
>>> Here is the full patch I have made to our local installation:
>>> bash-3.2$ diff rtems_bsdnet_ntp.c rtems_bsdnet_ntp.c.orig
>>> 143a144,146
>>>>        /* Changed ntp packet version match from '3' to '3 or 4', since
>>> version 4 will still work
>>>>                 panetta at slac.stanford.edu 2013-02-22
>>> 145c148,149
>>> <               ((packet.li_vn_mode & (0x7 << 3)) == (3 << 3)) &&
>>>>                (((packet.li_vn_mode & (0x7 << 3)) == (3 << 3)) ||
>>>>                 ((packet.li_vn_mode & (0x7 << 3)) == (4 << 3))) &&
>>> 179c183
>>> <       myAddr.sin_port = htons (0);
>>>>        myAddr.sin_port = htons (123);
>>> 195c199
>>> <               if (rtems_bsdnet_ntpserver_count < 0) {
>>>>                if (rtems_bsdnet_ntpserver_count <= 0) {
>>> Prior to this being committed, Joel and/or Eric should probably weigh in.
>>> Thanks,
>>>    --Jim Panetta  panetta at slac.stanford.edu
>>> My opinions are mine...not DOE's...not SLAC's...mine.
>>> (except by random, unforseeable coincidences)
>>> panetta at slac.stanford.edu  --  Save the whales!  Free the mallocs!
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
