CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
Maldonado, Sergio E.
smaldona at slac.stanford.edu
Fri Nov 15 00:06:14 UTC 2013
Hello,
I'm a user of RTEMS 4.10.99 and would like to exercise the parameter CONFIGURE_HAS_OWN_CONFIGURATION_TABLE as specified in 23.14.2 of the RTEMS C User's Guide (24 Feb 2013).
When this parameter is defined, how should a user instantiate the rtems_configuration_table structure for use by the executive?
In this release, must the structure be linked in by the user code, or can it still be passed in as a run time argument?
Thank you,
Sergio Maldonado
SLAC
