CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Nov 15 00:09:37 UTC 2013
On 11/14/2013 6:06 PM, Maldonado, Sergio E. wrote:
> Hello,
> I'm a user of RTEMS 4.10.99 and would like to exercise the parameter CONFIGURE_HAS_OWN_CONFIGURATION_TABLE as specified in 23.14.2 of the RTEMS C User's Guide (24 Feb 2013).
> When this parameter is defined, how should a user instantiate the rtems_configuration_table structure for use by the executive?
> In this release, must the structure be linked in by the user code, or can it still be passed in as a run time argument?
You almost certainly don't want to do that. :)
Why do you think you want to fill inby hand a large and
complex data structure that is subject to change with each
release?
I was the one who added that option and I have considered
removing it many times. I just can't see any good use case
for exercising it.
Prove me wrong. :)
> Thank you,
> Sergio Maldonado
> SLAC
> rtems-devel mailing list
> rtems-devel at rtems.org
