[SOCIS] Testing Framework
    Sebastian Huber
    Wed Nov 20 15:11:13 UTC 2013
Hello Marcin,
I just checked out the Unity sources and had a brief look at it.  I see one
major problem with this framework.  It is not thread-safe, e.g. you have
functions like this:
https://github.com/ThrowTheSwitch/Unity/blob/master/src/unity.c
void UnityAssertNumbersWithin( const _U_SINT delta,
                                const _U_SINT expected,
                                const _U_SINT actual,
                                const char* msg,
                                const UNITY_LINE_TYPE lineNumber,
                                const UNITY_DISPLAY_STYLE_T style)
     UNITY_SKIP_EXECUTION;
     if ((style & UNITY_DISPLAY_RANGE_INT) == UNITY_DISPLAY_RANGE_INT)
         if (actual > expected)
           Unity.CurrentTestFailed = ((actual - expected) > delta);
         else
           Unity.CurrentTestFailed = ((expected - actual) > delta);
     else
         if ((_U_UINT)actual > (_U_UINT)expected)
             Unity.CurrentTestFailed = ((_U_UINT)(actual - expected) >
(_U_UINT)delta);
         else
             Unity.CurrentTestFailed = ((_U_UINT)(expected - actual) >
(_U_UINT)delta);
     if (Unity.CurrentTestFailed)
         UnityTestResultsFailBegin(lineNumber);
         UnityPrint(UnityStrDelta);
         UnityPrintNumberByStyle(delta, style);
         UnityPrint(UnityStrExpected);
         UnityPrintNumberByStyle(expected, style);
         UnityPrint(UnityStrWas);
         UnityPrintNumberByStyle(actual, style);
         UnityAddMsgIfSpecified(msg);
         UNITY_FAIL_AND_BAIL;
So now if multiple threads call this function the result is unpredictable.
Thread-safety is a mandatory feature for a unit test framework for RTEMS from
my point of view, so either we add this to Unity or search for something else.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
