[SOCIS] Testing Framework
Marcin Bujar
marcin.bujar at gmail.com
Thu Nov 21 14:20:24 UTC 2013
Hi Sebastian,
Unfortunately the project was on hold for a while now due to administrative
reasons. I am just about get back into it so expect more updates soon.
As to the thread safety of Unity I was not aware that was an explicit
requirement for a testing framework. If you are referring to accessing the
Unity struct then this is something I could serialize, or even better I
will check if somebody has implemented this already.
Thanks for pointing it out.
Marcin
On 20 November 2013 16:11, Sebastian Huber <
> Hello Marcin,
> I just checked out the Unity sources and had a brief look at it. I see
> one major problem with this framework. It is not thread-safe, e.g. you
> have functions like this:
> https://github.com/ThrowTheSwitch/Unity/blob/master/src/unity.c
> void UnityAssertNumbersWithin( const _U_SINT delta,
> const _U_SINT expected,
> const _U_SINT actual,
> const char* msg,
> const UNITY_LINE_TYPE lineNumber,
> const UNITY_DISPLAY_STYLE_T style)
> UNITY_SKIP_EXECUTION;
> if ((style & UNITY_DISPLAY_RANGE_INT) == UNITY_DISPLAY_RANGE_INT)
> if (actual > expected)
> Unity.CurrentTestFailed = ((actual - expected) > delta);
> else
> Unity.CurrentTestFailed = ((expected - actual) > delta);
> else
> if ((_U_UINT)actual > (_U_UINT)expected)
> Unity.CurrentTestFailed = ((_U_UINT)(actual - expected) >
> (_U_UINT)delta);
> else
> Unity.CurrentTestFailed = ((_U_UINT)(expected - actual) >
> (_U_UINT)delta);
> if (Unity.CurrentTestFailed)
> UnityTestResultsFailBegin(lineNumber);
> UnityPrint(UnityStrDelta);
> UnityPrintNumberByStyle(delta, style);
> UnityPrint(UnityStrExpected);
> UnityPrintNumberByStyle(expected, style);
> UnityPrint(UnityStrWas);
> UnityPrintNumberByStyle(actual, style);
> UnityAddMsgIfSpecified(msg);
> UNITY_FAIL_AND_BAIL;
> So now if multiple threads call this function the result is unpredictable.
> Thread-safety is a mandatory feature for a unit test framework for RTEMS
> from my point of view, so either we add this to Unity or search for
> something else.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20131121/fc863a26/attachment.html>
