Interrupt Processor Affinity API Changes
Thu Nov 21 11:09:10 UTC 2013
Hello,
this is a proposal for an update of the Interrupt Manager Extension
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__rtems__interrupt__extension.html
to allow set/get of processor affinities for interrupt vectors.
==== RTEMS API Changes ====
Each interrupt needs a processor affinity set in the RTEMS SMP configuration.
The rtems_interrupt_handler_install() function will not alter the processor
affinity set of the interrupt vector.
Two new functions should be added to alter and retrieve the processor affinity
sets of interrupt vectors.
   * @brief Sets the processor affinity set of an interrupt vector.
   * @param[in] vector The interrupt vector number.
   * @param[in] affinity_set_size Size of the specified affinity set buffer in
   * bytes.  This value must be positive.
   * @param[in] affinity_set The new processor affinity set for the interrupt
   * vector.  This pointer must not be @c NULL.  A set bit in the affinity set
   * means that the interrupt vector can occur on this processor and a cleared
   * bit means the opposite.
   * @retval RTEMS_SUCCESSFUL Successful operation.
   * @retval RTEMS_INVALID_ID The vector number is invalid.
   * @retval RTEMS_INVALID_CPU_SET Invalid processor affinity set.
  rtems_status_code rtems_interrupt_set_affinity(
    rtems_vector vector,
    size_t affinity_set_size,
    const cpu_set_t *affinity_set
   * @brief Gets the processor affinity set of an interrupt vector.
   * @param[out] affinity_set The current processor affinity set of the
   * interrupt vector.  This pointer must not be @c NULL.  A set bit in the
   * affinity set means that the interrupt vector can occur on this processor
   * and a cleared bit means the opposite.
   * @retval RTEMS_INVALID_CPU_SET The affinity set buffer is too small for the
   * current processor affinity set of the interrupt vector.
  rtems_status_code rtems_interrupt_get_affinity(
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
