[SOCIS] Testing Framework
Sat Nov 23 15:05:47 UTC 2013
The article [1] might be relevant.
-Gedare
[1] http://www.sciencedirect.com/science/article/pii/S0167642312000317
On Thu, Nov 21, 2013 at 9:20 AM, Marcin Bujar <marcin.bujar at gmail.com> wrote:
> Hi Sebastian,
> Unfortunately the project was on hold for a while now due to administrative
> reasons. I am just about get back into it so expect more updates soon.
> As to the thread safety of Unity I was not aware that was an explicit
> requirement for a testing framework. If you are referring to accessing the
> Unity struct then this is something I could serialize, or even better I will
> check if somebody has implemented this already.
> Thanks for pointing it out.
> Marcin
> On 20 November 2013 16:11, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Hello Marcin,
>> I just checked out the Unity sources and had a brief look at it.  I see
>> one major problem with this framework.  It is not thread-safe, e.g. you have
>> functions like this:
>> https://github.com/ThrowTheSwitch/Unity/blob/master/src/unity.c
>> void UnityAssertNumbersWithin( const _U_SINT delta,
>>                                const _U_SINT expected,
>>                                const _U_SINT actual,
>>                                const char* msg,
>>                                const UNITY_LINE_TYPE lineNumber,
>>                                const UNITY_DISPLAY_STYLE_T style)
>>     UNITY_SKIP_EXECUTION;
>>     if ((style & UNITY_DISPLAY_RANGE_INT) == UNITY_DISPLAY_RANGE_INT)
>>         if (actual > expected)
>>           Unity.CurrentTestFailed = ((actual - expected) > delta);
>>         else
>>           Unity.CurrentTestFailed = ((expected - actual) > delta);
>>     else
>>         if ((_U_UINT)actual > (_U_UINT)expected)
>>             Unity.CurrentTestFailed = ((_U_UINT)(actual - expected) >
>> (_U_UINT)delta);
>>         else
>>             Unity.CurrentTestFailed = ((_U_UINT)(expected - actual) >
>> (_U_UINT)delta);
>>     if (Unity.CurrentTestFailed)
>>         UnityTestResultsFailBegin(lineNumber);
>>         UnityPrint(UnityStrDelta);
>>         UnityPrintNumberByStyle(delta, style);
>>         UnityPrint(UnityStrExpected);
>>         UnityPrintNumberByStyle(expected, style);
>>         UnityPrint(UnityStrWas);
>>         UnityPrintNumberByStyle(actual, style);
>>         UnityAddMsgIfSpecified(msg);
>>         UNITY_FAIL_AND_BAIL;
>> So now if multiple threads call this function the result is unpredictable.
>> Thread-safety is a mandatory feature for a unit test framework for RTEMS
>> from my point of view, so either we add this to Unity or search for
>> something else.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> rtems-devel mailing list
> rtems-devel at rtems.org
