[PATCH] Mongoose HTTPd from 3.2 to 3.9 (last commit before MIT -> GPL)
Gedare Bloom
gedare at rtems.org
Thu Nov 7 14:12:17 UTC 2013
Hi Nick,
I don't have a network-capable RTEMS setup at the moment, so I can't
test/commit. However, have you tested the patched version? What RTEMS
version (HEAD?) did you use, and what BSP?
-Gedare
On Thu, Nov 7, 2013 at 5:28 AM, Nick Withers <nick.withers at anu.edu.au> wrote:
> On Thu, 2013-11-07 at 17:59 +1100, Nick Withers wrote:
>> Hey all,
>> The following patch updates the Mongoose HTTP server from 3.2 to 3.9, at
>> the last point before the MIT -> GPL license change (going off the
>> author's confirmation at https://groups.google.com/forum/#!
>> topic/mongoose-users/aafbOnHonkI ).
> The attached restores the sys/select.h include and static-ifies some
> functions to kill warnings.
>> ____
>> From 76c451c9d101068dee796b715d2201d6956b0347 Mon Sep 17 00:00:00 2001
>> From: Nick Withers <nick.withers at anu.edu.au>
>> Date: Thu, 7 Nov 2013 17:46:54 +1100
>> Subject: [PATCH] Update to Mongoose 3.9 at the last point before the MIT ->
>> GPL license change
>> [See https://groups.google.com/forum/#!topic/mongoose-users/aafbOnHonkI regarding license change]
>> The RTEMS patches described in the following emails and made to the previous Mongoose base have been applied:
>> - http://www.rtems.org/pipermail/rtems-devel/2012-July/001345.html
>> - http://www.rtems.org/pipermail/rtems-devel/2012-July/001343.html
>> - http://www.rtems.org/pipermail/rtems-devel/2012-July/001346.html (except to mongoose.1, see below)
>> ...as well as a patch very similar to that discussed at http://forums.bannister.org/ubbthreads.php?ubb=showflat&topic=7600&gonew=1 to provide poll() (which might be able to go away soon, with incoming RTEMS poll() support)
>> mongoose.1 appears to have been removed from the upstream distribution.
>> Note that the short form of options (e.g., "u" instead of "run_as_user") are no longer available (upstream)
> (snip)
>> ____
>> Anyone keen to commit it? Perhaps killing the man page isn't the way to
>> go?
>> My personal motivation is that I want to use (or at least, investigate)
>> WebSockets, which aren't supported by Mongoose 3.2.
> Nick Withers
> Embedded Systems Programmer
> Room 2.26, Building 57
> Department of Nuclear Physics
> Research School of Physics and Engineering
> The Australian National University (CRICOS: 00120C)
> eMail: nick.withers at anu.edu.au
> Phone: +61 2 6125 2091
> Mobile: +61 414 397 446
> rtems-devel mailing list
> rtems-devel at rtems.org
