[PATCH] Mongoose HTTPd from 3.2 to 3.9 (last commit before MIT -> GPL)
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Nov 7 14:59:59 UTC 2013
Thanks Nick for doing this. We will need to decide
how to handle the license change. There is a fork
maintained here which was triggered by the license
change.
http://sourceforge.net/projects/civetweb/
We were not the only project concerned about the license
change.
Gedare.. there is at least one loopback test in the tree
for mghttpd.
--joel
On 11/7/2013 8:12 AM, Gedare Bloom wrote:
> Hi Nick,
> I don't have a network-capable RTEMS setup at the moment, so I can't
> test/commit. However, have you tested the patched version? What RTEMS
> version (HEAD?) did you use, and what BSP?
> -Gedare
> On Thu, Nov 7, 2013 at 5:28 AM, Nick Withers <nick.withers at anu.edu.au> wrote:
>> On Thu, 2013-11-07 at 17:59 +1100, Nick Withers wrote:
>>> Hey all,
>>> The following patch updates the Mongoose HTTP server from 3.2 to 3.9, at
>>> the last point before the MIT -> GPL license change (going off the
>>> author's confirmation at https://groups.google.com/forum/#!
>>> topic/mongoose-users/aafbOnHonkI ).
>> The attached restores the sys/select.h include and static-ifies some
>> functions to kill warnings.
>>> ____
>>> From 76c451c9d101068dee796b715d2201d6956b0347 Mon Sep 17 00:00:00 2001
>>> From: Nick Withers <nick.withers at anu.edu.au>
>>> Date: Thu, 7 Nov 2013 17:46:54 +1100
>>> Subject: [PATCH] Update to Mongoose 3.9 at the last point before the MIT ->
>>> GPL license change
>>> [See https://groups.google.com/forum/#!topic/mongoose-users/aafbOnHonkI regarding license change]
>>> The RTEMS patches described in the following emails and made to the previous Mongoose base have been applied:
>>> - http://www.rtems.org/pipermail/rtems-devel/2012-July/001345.html
>>> - http://www.rtems.org/pipermail/rtems-devel/2012-July/001343.html
>>> - http://www.rtems.org/pipermail/rtems-devel/2012-July/001346.html (except to mongoose.1, see below)
>>> ...as well as a patch very similar to that discussed at http://forums.bannister.org/ubbthreads.php?ubb=showflat&topic=7600&gonew=1 to provide poll() (which might be able to go away soon, with incoming RTEMS poll() support)
>>> mongoose.1 appears to have been removed from the upstream distribution.
>>> Note that the short form of options (e.g., "u" instead of "run_as_user") are no longer available (upstream)
>> (snip)
>>> ____
>>> Anyone keen to commit it? Perhaps killing the man page isn't the way to
>>> go?
>>> My personal motivation is that I want to use (or at least, investigate)
>>> WebSockets, which aren't supported by Mongoose 3.2.
>> Nick Withers
>> Embedded Systems Programmer
>> Room 2.26, Building 57
>> Department of Nuclear Physics
>> Research School of Physics and Engineering
>> The Australian National University (CRICOS: 00120C)
>> eMail: nick.withers at anu.edu.au
>> Phone: +61 2 6125 2091
>> Mobile: +61 414 397 446
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
