score support for cpuset validation
Gedare Bloom
gedare at rtems.org
Tue Nov 26 20:23:44 UTC 2013
Does it make sense to have separate methods for the validation of the
different cases? I would think the usage would be "err =
validate(cpuset *s);" which could be propagated through the return
value regardless of the condition?
On Tue, Nov 26, 2013 at 3:17 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> And in case the error cases are not completely clear,
> do a "man pthread_setaffinity_np" on Linux and see
> the errors returned. :)
> On 11/26/2013 1:15 PM, Joel Sherrill wrote:
>> FWIW these are likely three separate methods. We may
>> need a new handler. So think long term when making
>> suggestions.
>> On 11/26/2013 1:11 PM, Jennifer Averett wrote:
>>> I’d like to add a method to the super core to validate
>>> a cpuset:
>>> 1) Can’t have a cpuset that is sets a cpu greater than the number
>>> of cores
>>> 2) Can’t have a cpuset that is sets a cpu that is turned off or
>>> not running rtems…
>>> 3) Can’t have a cpuset with no cpu’s selected.
>>> Any suggestions for a method name, location, … ?
>>> Jennifer Averett
>>> On-Line Applications Research
>>> 256-319-2752
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> rtems-devel mailing list
> rtems-devel at rtems.org
