score support for cpuset validation
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Nov 26 20:31:24 UTC 2013
On 11/26/2013 2:23 PM, Gedare Bloom wrote:
> Does it make sense to have separate methods for the validation of the
> different cases? I would think the usage would be "err =
> validate(cpuset *s);" which could be propagated through the return
> value regardless of the condition?
I don't know. That's why the discussion. Certainly
checking it against CPUs available is a Score matter.
> On Tue, Nov 26, 2013 at 3:17 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> And in case the error cases are not completely clear,
>> do a "man pthread_setaffinity_np" on Linux and see
>> the errors returned. :)
>> On 11/26/2013 1:15 PM, Joel Sherrill wrote:
>>> FWIW these are likely three separate methods. We may
>>> need a new handler. So think long term when making
>>> suggestions.
>>> On 11/26/2013 1:11 PM, Jennifer Averett wrote:
>>>> I’d like to add a method to the super core to validate
>>>> a cpuset:
>>>> 1) Can’t have a cpuset that is sets a cpu greater than the number
>>>> of cores
>>>> 2) Can’t have a cpuset that is sets a cpu that is turned off or
>>>> not running rtems…
>>>> 3) Can’t have a cpuset with no cpu’s selected.
>>>> Any suggestions for a method name, location, … ?
>>>> Jennifer Averett
>>>> On-Line Applications Research
>>>> 256-319-2752
>> Joel Sherrill, Ph.D. Director of Research & Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
