[rtems-libbsd commit] Change license to BSD
Wed Oct 9 21:11:18 UTC 2013
Let this be a public statement that any OAR developed code in
this git module can follow the same 2 clause license.
--joel
On 10/9/2013 10:43 AM, Sebastian Huber wrote:
> Module:    rtems-libbsd
> Branch:    master
> Commit:    ddc3de50a1f6888a97b5a9e6a6673a71ef72a352
> Changeset: http://git.rtems.org/rtems-libbsd/commit/?id=ddc3de50a1f6888a97b5a9e6a6673a71ef72a352
> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date:      Wed Oct  9 09:00:44 2013 +0200
>  rtemsbsd/include/machine/rtems-bsd-config.h.in |   27 +++++++++++++++++++----
>  1 files changed, 22 insertions(+), 5 deletions(-)
> diff --git a/rtemsbsd/include/machine/rtems-bsd-config.h.in b/rtemsbsd/include/machine/rtems-bsd-config.h.in
> index 64dce1c..3990710 100644
> --- a/rtemsbsd/include/machine/rtems-bsd-config.h.in
> +++ b/rtemsbsd/include/machine/rtems-bsd-config.h.in
> @@ -7,17 +7,34 @@
> - * Copyright (c) 2009, 2010 embedded brains GmbH.  All rights reserved.
> + * Copyright (c) 2009-2013 embedded brains GmbH.  All rights reserved.
>   *  embedded brains GmbH
> - *  Obere Lagerstr. 30
> + *  Dornierstr. 4
>   *  82178 Puchheim
>   *  Germany
>   *  <rtems at embedded-brains.de>
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.com/license/LICENSE.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
>  #ifndef _RTEMS_BSD_MACHINE_RTEMS_BSD_CONFIG_H_
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
