New configure option RTEMS_VIRTUAL
Fri Oct 11 17:54:29 UTC 2013
I would like to make one other suggestion, which is:
RTEMS_PARAVIRT, and --enable-paravirt.
This option is consistent with the language already used to describe
what is being done, i.e. paravirtualization of some pieces of RTEMS.
All in favor?
-Gedare
On Tue, Sep 17, 2013 at 4:26 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 9/17/2013 3:21 PM, Chris Johns wrote:
>> Gedare Bloom wrote:
>>>> RTEMS_HYPERVISOR or RTEMS_VIRTUAL
>>> I'm preferential to this high-level switch. I would avoid
>>> RTEMS_HYPERVISOR, because RTEMS is not the hypervisor, it is the guest
>>> VM.
>> And RTEMS_VIRTUAL could be taken to mean RTEMS supports virtual memory.
>> What about RTEMS_HYPERVISOR_GUEST ?
> That's a better name. What would the configure option be?
> --enable-hypervisor-guest?
>> Chris
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
