[PATCH] Modify raspberrypi mm_config_table to map GPIO and registers.
Hesham Moustafa
heshamelmatary at gmail.com
Tue Oct 15 20:04:31 UTC 2013
On Tue, Oct 15, 2013 at 1:39 AM, Chris Johns <chrisj at rtems.org> wrote:
> Hesham Moustafa wrote:
>> On Mon, Oct 14, 2013 at 4:02 PM, Sebastian Huber
>> <sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
>> <mailto:sebastian.huber@**embedded-brains.de<sebastian.huber at embedded-brains.de>>>
>> wrote:
>> On 2013-10-14 15:34, Hesham AL-Matary wrote:
>> diff --git
>> a/c/src/lib/libbsp/arm/__**raspberrypi/startup/mm_config_**
>> __table.c
>> b/c/src/lib/libbsp/arm/__**raspberrypi/startup/mm_config_**
>> __table.c
>> index 5436a76..2b748b2 100644
>> --- a/c/src/lib/libbsp/arm/__**raspberrypi/startup/mm_config_**
>> __table.c
>> +++ b/c/src/lib/libbsp/arm/__**raspberrypi/startup/mm_config_**
>> __table.c
>> @@ -42,7 +42,7 @@ bsp_mm_config_table[] = {
>> .begin = (uint32_t) bsp_section_text_begin,
>> .end = (uint32_t) bsp_section_text_end,
>> - .flags = ARMV7_MMU_CODE_CACHED
>> + .flags = ARMV7_MMU_READ_WRITE
>> What is the problem with the cache? Did the cache previously work?
>> There is a problem with applying a Read-Only permissions in general to
>> this
>> area for RaspberryPi BSP.
> What is the reason ?
> I am not sure about that.
>> .begin = (uint32_t) bsp_section_rodata_begin,
>> .end = (uint32_t) bsp_section_rodata_end,
>> @@ -63,8 +63,12 @@ bsp_mm_config_table[] = {
>> .begin = (uint32_t) bsp_section_stack_begin,
>> .end = (uint32_t) bsp_section_stack_end,
>> .flags = MMU_DATA_READ_WRITE
>> + .begin = 0x20000000,
>> + .end = 0x20FFFFFF,
>> + .flags = ARMV7_MMU_DATA_READ_WRITE
>> What is this for an area?
>> It's for Raspberry GPIO pins and other registers (defined at
>> raspbberrypi.h).
> Should this be ARMV7_MMU_DEVICE and not ARMV7_MMU_DATA_READ_WRITE ?
Both works fine. I noticed that other folks map this area as rw (via
mman.h) on raspberrypi OS.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20131015/76bb8829/attachment.html>
