cpuset macro /vs/ inline implementation
Daniel Hellstrom
daniel at gaisler.com
Thu Oct 31 11:30:04 UTC 2013
Hello Jennifer,
I think it looks good. I have small comments and nitpicks ;)
I see that the cpu_set_word_t is set to 32-bit which suites most CPUs, there is probably a good reason for it but would it make sens to make it dependent on the architecture? So that 64-bit machines
have it sized to 64-bits. I'm not sure there are 16-bit SMP machines :) . The rest of the code seems to support it by scaling depending on the size of that type.
> /* fill set */
> static inline void CPU_FILL(cpu_set_t *set)
> size_t i;
> for (i = 0; i < _NCPUWORDS; i++)
> - set->__bits[i] = -1;
> + set->__bits[i] = ~0;
bits[] is declared as unsigned, the above it perhaps a better solution?
> /* Return 1 is cpu is set in set, 0 otherwise */
> static inline int const CPU_ISSET(size_t cpu, const cpu_set_t *set)
> return ((set->__bits[__cpuset_index(cpu)] & __cpuset_mask(cpu)) != 0);
Return 1 *if* cpu..
> /* return the number of set cpus in set */
> static inline int const CPU_COUNT(const cpu_set_t *set)
> size_t i;
> int count = 0;
indent error.
> for (i=0; i < _NCPUWORDS; i++)
> if (CPU_ISSET(i, set) != 0)
> count++;
> return count;
Another unimportant note, I see that some of the arguments are separated with a space and some not.. unless its my email clients work.
Thanks for a good job in defining and implementing the cpuset API!
Daniel
On 10/28/2013 06:23 PM, Jennifer Averett wrote:
> I attached the latest cpuset. From the discussions
> we are going with the inline version and I think I have incorporated
> all previous comments into the file.
> Are there any more comments or discussion?
> Jennifer Averett
> On-Line Applications Research
> rtems-devel mailing list
> rtems-devel at rtems.org
