cpuset macro /vs/ inline implementation
    Sebastian Huber
    Thu Oct 31 11:38:04 UTC 2013
On 2013-10-31 12:30, Daniel Hellstrom wrote:
> I see that the cpu_set_word_t is set to 32-bit which suites most CPUs, there is
> probably a good reason for it but would it make sens to make it dependent on
> the architecture? So that 64-bit machines have it sized to 64-bits. I'm not
> sure there are 16-bit SMP machines :) .
No, this should be a fixed size integer for all architectures to allow static
initialization.  Anyway it will be a long way for RTEMS to support 33 processors.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
