[PATCH] shell: Out-of-bounds access
Thu Sep 5 16:18:46 UTC 2013
In case the length of cwd path plus the userScriptName exceeds
PATH_MAX (255), the strncat calls will overflow scriptFile. Also
check for getcwd failure.
 cpukit/libmisc/shell/shell_script.c |   23 +++++++++++++++--------
 1 files changed, 15 insertions(+), 8 deletions(-)
diff --git a/cpukit/libmisc/shell/shell_script.c b/cpukit/libmisc/shell/shell_script.c
index 98d0a5b..c055e3f 100644
--- a/cpukit/libmisc/shell/shell_script.c
+++ b/cpukit/libmisc/shell/shell_script.c
@@ -50,6 +50,7 @@ static int findOnPATH(
   int sc;
+  char *cwd;
    *  If the user script name starts with a / assume it is a fully
@@ -65,14 +66,20 @@ static int findOnPATH(
     /* XXX should use strncat but what is the limit? */
-    getcwd( scriptFile, PATH_MAX );
-    strncat( scriptFile, "/", PATH_MAX );
-    strncat(
-      scriptFile,
-      ( (userScriptName[0] == '.' && userScriptName[1] == '/') ?
-         &userScriptName[2] : userScriptName),
-      PATH_MAX
+    cwd = getcwd( scriptFile, PATH_MAX );
+    if ( cwd != NULL ) {
+      int cwdlen = strnlen( scriptFile, PATH_MAX );
+      strncat( scriptFile, "/", PATH_MAX - cwdlen );
+      strncat(
+          scriptFile,
+          ( (userScriptName[0] == '.' && userScriptName[1] == '/') ?
+            &userScriptName[2] : userScriptName),
+          PATH_MAX - cwdlen - 1
+    } else {
+      return -1;
   sc = access( scriptFile, R_OK );
1.7.1
