[PATCH] shell: Out-of-bounds access
Gedare Bloom
gedare at rtems.org
Thu Sep 5 16:32:14 UTC 2013
On Thu, Sep 5, 2013 at 12:18 PM, Gedare Bloom <gedare at rtems.org> wrote:
> In case the length of cwd path plus the userScriptName exceeds
> PATH_MAX (255), the strncat calls will overflow scriptFile. Also
> check for getcwd failure.
> cpukit/libmisc/shell/shell_script.c | 23 +++++++++++++++--------
> 1 files changed, 15 insertions(+), 8 deletions(-)
> diff --git a/cpukit/libmisc/shell/shell_script.c b/cpukit/libmisc/shell/shell_script.c
> index 98d0a5b..c055e3f 100644
> --- a/cpukit/libmisc/shell/shell_script.c
> +++ b/cpukit/libmisc/shell/shell_script.c
> @@ -50,6 +50,7 @@ static int findOnPATH(
> int sc;
> + char *cwd;
> * If the user script name starts with a / assume it is a fully
> @@ -65,14 +66,20 @@ static int findOnPATH(
> /* XXX should use strncat but what is the limit? */
> - getcwd( scriptFile, PATH_MAX );
> - strncat( scriptFile, "/", PATH_MAX );
> - strncat(
> - scriptFile,
> - ( (userScriptName[0] == '.' && userScriptName[1] == '/') ?
> - &userScriptName[2] : userScriptName),
> - PATH_MAX
> + cwd = getcwd( scriptFile, PATH_MAX );
> + if ( cwd != NULL ) {
> + int cwdlen = strnlen( scriptFile, PATH_MAX );
> + strncat( scriptFile, "/", PATH_MAX - cwdlen );
> + strncat(
> + scriptFile,
> + ( (userScriptName[0] == '.' && userScriptName[1] == '/') ?
> + &userScriptName[2] : userScriptName),
> + PATH_MAX - cwdlen - 1
A different fix for this would be to use strlcat() instead, which will
compute the space available in the scriptFile destination.
> + } else {
> + return -1;
> sc = access( scriptFile, R_OK );
> 1.7.1
