[PATCH] bdpart: Argument cannot be negative
Gedare Bloom
gedare at rtems.org
Thu Sep 5 17:24:23 UTC 2013
If open(fd) fails then avoid the error path that calls close(fd).
cpukit/libblock/src/bdpart-read.c | 5 +++--
1 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/cpukit/libblock/src/bdpart-read.c b/cpukit/libblock/src/bdpart-read.c
index fd8a038..cfb31d5 100644
--- a/cpukit/libblock/src/bdpart-read.c
+++ b/cpukit/libblock/src/bdpart-read.c
@@ -74,7 +74,7 @@ rtems_status_code rtems_bdpart_get_disk_data(
rtems_status_code sc = RTEMS_SUCCESSFUL;
int rv = 0;
- int fd = -1;
+ int fd;
rtems_disk_device *dd = NULL;
rtems_blkdev_bnum disk_begin = 0;
rtems_blkdev_bnum block_size = 0;
@@ -83,7 +83,7 @@ rtems_status_code rtems_bdpart_get_disk_data(
fd = open( disk_name, O_RDWR);
if (fd < 0) {
sc = RTEMS_INVALID_NAME;
- goto error;
+ goto out;
/* Get disk handle */
@@ -119,6 +119,7 @@ error:
close( fd);
+out:
return sc;
1.7.1
