Files for Coverity Scan to Ignore
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Sep 5 21:26:49 UTC 2013
Hi
For Coverity Scan, I am building sparc/leon3 with the
following configure command:
$r/configure --target=${RTEMS_TARGET} --enable-smp \
--disable-networking --disable-itron --disable-tests \
--enable-rtemsbsp=${RTEMS_BSP} >c.log 2>&1
You can configure Scan to ignore certain file patterns.
I have told Scan to ignore
+ */libnetworking/*
+ */libbsp/*
+ */mghttpd/*
+ */zlib/*
I know two of these are not in the build due to disable
networking. zlib had positives that the maintainers knew of
and said were false positives when I ran those down. That's
why I am ignoring it.
Does this configuration and exclude file set make sense?
Is it too large or small?
Comments?
