[PATCH] Colon in module path fix
Mohammed Khoory mkhoory at eiast.ae
Fri Sep 6 02:34:31 UTC 2013
Hi,
This patch fixes an issue in the RTL target code that occurs when trying to
load a RAP/ELF module that is located in a directory which has a colon in
it.
Note: I based this commit off Peng Fan's repository.
Regards,
Mohammed Khoory
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130906/b0ad64ec/attachment.obj>
