[PATCH 1/2] Filesystem: Add and use rtems_filesystem_chmod()
Sebastian Huber
Wed Sep 11 09:01:11 UTC 2013
Implement POSIX requirements in the high-level file system layer.
cpukit/libcsupport/include/rtems/libio_.h | 5 +++
cpukit/libcsupport/src/chmod.c | 2 +-
cpukit/libcsupport/src/fchmod.c | 49 ++++++++++++++++++++++++-----
cpukit/libfs/src/imfs/imfs_fchmod.c | 20 +-----------
cpukit/libfs/src/rfs/rtems-rfs-rtems.c | 24 +-------------
5 files changed, 49 insertions(+), 51 deletions(-)
diff --git a/cpukit/libcsupport/include/rtems/libio_.h b/cpukit/libcsupport/include/rtems/libio_.h
index 55156c0..4a0623e 100644
--- a/cpukit/libcsupport/include/rtems/libio_.h
+++ b/cpukit/libcsupport/include/rtems/libio_.h
@@ -566,6 +566,11 @@ int rtems_filesystem_mknod(
int rtems_filesystem_chdir( rtems_filesystem_location_info_t *loc );
+int rtems_filesystem_chmod(
+ const rtems_filesystem_location_info_t *loc,
+ mode_t mode
int rtems_filesystem_chown(
const char *path,
uid_t owner,
diff --git a/cpukit/libcsupport/src/chmod.c b/cpukit/libcsupport/src/chmod.c
index 8b91b60..a8785d4 100644
--- a/cpukit/libcsupport/src/chmod.c
+++ b/cpukit/libcsupport/src/chmod.c
@@ -33,7 +33,7 @@ int chmod( const char *path, mode_t mode )
const rtems_filesystem_location_info_t *currentloc =
rtems_filesystem_eval_path_start( &ctx, path, eval_flags );
- rv = (*currentloc->mt_entry->ops->fchmod_h)( currentloc, mode );
+ rv = rtems_filesystem_chmod( currentloc, mode );
rtems_filesystem_eval_path_cleanup( &ctx );
diff --git a/cpukit/libcsupport/src/fchmod.c b/cpukit/libcsupport/src/fchmod.c
index 94e8264..b8f4d33 100644
--- a/cpukit/libcsupport/src/fchmod.c
+++ b/cpukit/libcsupport/src/fchmod.c
@@ -22,6 +22,42 @@
#include <rtems/libio_.h>
+ mode_t mode
+ const rtems_filesystem_mount_table_entry_t *mt_entry = loc->mt_entry;
+ int rv;
+ if ( mt_entry->writeable || rtems_filesystem_location_is_null( loc ) ) {
+ struct stat st;
+ memset( &st, 0, sizeof(st) );
+ rv = (*loc->handlers->fstat_h)( loc, &st );
+ if ( rv == 0 ) {
+ uid_t uid = geteuid();
+ if ( uid == 0 || st.st_uid == uid ) {
+ mode_t mask = S_IRWXU | S_IRWXG | S_IRWXO | S_ISUID | S_ISGID | S_ISVTX;
+ mode = (st.st_mode & ~mask) | (mode & mask);
+ rv = (*mt_entry->ops->fchmod_h)( loc, mode );
+ } else {
+ errno = EPERM;
+ rv = -1;
+ } else {
+ errno = EROFS;
+ rv = -1;
+ return rv;
* POSIX 1003.1b 5.6.4 - Change File Modes
@@ -34,14 +70,11 @@ int fchmod( int fd, mode_t mode )
iop = rtems_libio_iop( fd );
rtems_libio_check_is_open(iop);
- if (iop->pathinfo.mt_entry->writeable) {
- rtems_filesystem_instance_lock( &iop->pathinfo );
- rv = (*iop->pathinfo.mt_entry->ops->fchmod_h)( &iop->pathinfo, mode );
- rtems_filesystem_instance_unlock( &iop->pathinfo );
- } else {
- errno = EROFS;
- rv = -1;
+ rtems_filesystem_instance_lock( &iop->pathinfo );
+ rv = rtems_filesystem_chmod( &iop->pathinfo, mode );
+ rtems_filesystem_instance_unlock( &iop->pathinfo );
return rv;
diff --git a/cpukit/libfs/src/imfs/imfs_fchmod.c b/cpukit/libfs/src/imfs/imfs_fchmod.c
index ccb3446..5111944 100644
--- a/cpukit/libfs/src/imfs/imfs_fchmod.c
+++ b/cpukit/libfs/src/imfs/imfs_fchmod.c
@@ -26,28 +26,10 @@ int IMFS_fchmod(
IMFS_jnode_t *jnode;
-#if defined(RTEMS_POSIX_API)
- uid_t st_uid;
-#endif
jnode = loc->node_access;
- * Verify I am the owner of the node or the super user.
- st_uid = geteuid();
- if ( ( st_uid != jnode->st_uid ) && ( st_uid != 0 ) )
- rtems_set_errno_and_return_minus_one( EPERM );
-#endif
- * Change only the RWX permissions on the jnode to mode.
- jnode->st_mode &= ~(S_IRWXU | S_IRWXG | S_IRWXO | S_ISUID | S_ISGID | S_ISVTX);
- jnode->st_mode |= mode & (S_IRWXU | S_IRWXG | S_IRWXO | S_ISUID | S_ISGID | S_ISVTX);
+ jnode->st_mode = mode;
IMFS_update_ctime( jnode );
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
index 37daeea..4e3370b 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems.c
@@ -468,10 +468,6 @@ rtems_rfs_rtems_fchmod (const rtems_filesystem_location_info_t* pathloc,
rtems_rfs_file_system* fs = rtems_rfs_rtems_pathloc_dev (pathloc);
rtems_rfs_ino ino = rtems_rfs_rtems_get_pathloc_ino (pathloc);
rtems_rfs_inode_handle inode;
- uint16_t imode;
-#if defined (RTEMS_POSIX_API)
- uid_t uid;
-#endif
int rc;
if (rtems_rfs_rtems_trace (RTEMS_RFS_RTEMS_DEBUG_FCHMOD))
@@ -484,25 +480,7 @@ rtems_rfs_rtems_fchmod (const rtems_filesystem_location_info_t* pathloc,
return rtems_rfs_rtems_error ("fchmod: opening inode", rc);
- imode = rtems_rfs_inode_get_mode (&inode);
- uid = geteuid();
- if ((uid != rtems_rfs_inode_get_uid (&inode)) && (uid != 0))
- rtems_rfs_inode_close (fs, &inode);
- return rtems_rfs_rtems_error ("fchmod: checking uid", EPERM);
-#endif
- imode &= ~(S_IRWXU | S_IRWXG | S_IRWXO | S_ISUID | S_ISGID | S_ISVTX);
- imode |= mode & (S_IRWXU | S_IRWXG | S_IRWXO | S_ISUID | S_ISGID | S_ISVTX);
- rtems_rfs_inode_set_mode (&inode, imode);
+ rtems_rfs_inode_set_mode (&inode, mode);
rc = rtems_rfs_inode_close (fs, &inode);
if (rc > 0)
1.7.7
