[PATCH 2/2] Filesystem: Change rtems_filesystem_chown()
Sebastian Huber
Wed Sep 11 09:01:12 UTC 2013
Implement POSIX requirements in the high-level file system layer. Use
common implementation for all change owner variants.
cpukit/libcsupport/include/rtems/libio_.h | 5 +--
cpukit/libcsupport/src/chown.c | 25 ++++----------
cpukit/libcsupport/src/fchown.c | 52 +++++++++++++++++++++-------
cpukit/libcsupport/src/lchown.c | 17 ++++++---
4 files changed, 59 insertions(+), 40 deletions(-)
diff --git a/cpukit/libcsupport/include/rtems/libio_.h b/cpukit/libcsupport/include/rtems/libio_.h
index 4a0623e..8856566 100644
--- a/cpukit/libcsupport/include/rtems/libio_.h
+++ b/cpukit/libcsupport/include/rtems/libio_.h
@@ -572,10 +572,9 @@ int rtems_filesystem_chmod(
int rtems_filesystem_chown(
- const char *path,
+ const rtems_filesystem_location_info_t *loc,
uid_t owner,
- gid_t group,
- int eval_follow_link
+ gid_t group
static inline bool rtems_filesystem_is_ready_for_unmount(
diff --git a/cpukit/libcsupport/src/chown.c b/cpukit/libcsupport/src/chown.c
index 434fc2b..08ad8a2 100644
--- a/cpukit/libcsupport/src/chown.c
+++ b/cpukit/libcsupport/src/chown.c
@@ -25,31 +25,20 @@
#include <rtems/libio_.h>
-int rtems_filesystem_chown(
- const char *path,
- uid_t owner,
- gid_t group,
+ * POSIX 1003.1b 5.6.5 - Change Owner and Group of a File
+int chown( const char *path, uid_t owner, gid_t group )
- int rv = 0;
+ int rv;
rtems_filesystem_eval_path_context_t ctx;
- int eval_flags = eval_follow_link;
+ int eval_flags = RTEMS_FS_FOLLOW_LINK;
const rtems_filesystem_location_info_t *currentloc =
rtems_filesystem_eval_path_start( &ctx, path, eval_flags );
- const rtems_filesystem_operations_table *ops = currentloc->mt_entry->ops;
- rv = (*ops->chown_h)( currentloc, owner, group );
+ rv = rtems_filesystem_chown( currentloc, owner, group );
rtems_filesystem_eval_path_cleanup( &ctx );
return rv;
- * POSIX 1003.1b 5.6.5 - Change Owner and Group of a File
-int chown( const char *path, uid_t owner, gid_t group )
- return rtems_filesystem_chown( path, owner, group, RTEMS_FS_FOLLOW_LINK );
diff --git a/cpukit/libcsupport/src/fchown.c b/cpukit/libcsupport/src/fchown.c
index ec84fe4..2e74159 100644
--- a/cpukit/libcsupport/src/fchown.c
+++ b/cpukit/libcsupport/src/fchown.c
@@ -22,30 +22,56 @@
+int rtems_filesystem_chown(
+ uid_t owner,
+ gid_t group
+ const rtems_filesystem_mount_table_entry_t *mt_entry = loc->mt_entry;
+ int rv;
+ if ( mt_entry->writeable || rtems_filesystem_location_is_null( loc ) ) {
+ struct stat st;
+ memset( &st, 0, sizeof(st) );
+ rv = (*loc->handlers->fstat_h)( loc, &st );
+ if ( rv == 0 ) {
+ uid_t uid = geteuid();
+ if ( uid == 0 || st.st_uid == uid ) {
+ rv = (*mt_entry->ops->chown_h)( loc, owner, group );
+ } else {
+ errno = EPERM;
+ rv = -1;
+ } else {
+ errno = EROFS;
+ rv = -1;
+ return rv;
int fchown( int fd, uid_t owner, gid_t group )
- int rv = 0;
+ int rv;
rtems_libio_t *iop;
rtems_libio_check_fd( fd );
iop = rtems_libio_iop( fd );
rtems_libio_check_is_open(iop);
- if (iop->pathinfo.mt_entry->writeable) {
- rtems_filesystem_instance_lock( &iop->pathinfo );
- rv = (*iop->pathinfo.mt_entry->ops->chown_h)(
- &iop->pathinfo,
- owner,
- group
- rtems_filesystem_instance_unlock( &iop->pathinfo );
- } else {
- errno = EROFS;
- rv = -1;
+ rtems_filesystem_instance_lock( &iop->pathinfo );
+ rv = rtems_filesystem_chown( &iop->pathinfo, owner, group );
+ rtems_filesystem_instance_unlock( &iop->pathinfo );
return rv;
diff --git a/cpukit/libcsupport/src/lchown.c b/cpukit/libcsupport/src/lchown.c
index 406ac59..d6d20d6 100644
--- a/cpukit/libcsupport/src/lchown.c
+++ b/cpukit/libcsupport/src/lchown.c
@@ -19,10 +19,15 @@
int lchown( const char *path, uid_t owner, gid_t group )
- path,
- owner,
- group,
- RTEMS_FS_FOLLOW_HARD_LINK
+ int rv;
+ rtems_filesystem_eval_path_context_t ctx;
+ int eval_flags = RTEMS_FS_FOLLOW_HARD_LINK;
+ const rtems_filesystem_location_info_t *currentloc =
+ rtems_filesystem_eval_path_start( &ctx, path, eval_flags );
+ rtems_filesystem_eval_path_cleanup( &ctx );
+ return rv;
1.7.7
