[SOCIS] Testing Framework
Marcin Bujar
marcin.bujar at gmail.com
Mon Sep 16 19:53:19 UTC 2013
On 16 September 2013 12:31, Sebastian Huber <
> Hello Marcin,
> On 2013-09-15 22:34, Marcin Bujar wrote:
>> Hi again,
>> I would just like to update everybody that the work on my SOCIS project on
>> RTEMS testing framework is going well. This week I worked on adding new
>> features to the Unity unit testing tool, primarily adding JSON output
>> support
>> as mentioned in my previous update, but also looking how to compile the
>> program
>> on 16bit architecture so that it is executable on such RTEMS supported
>> platforms.
> it would be nice to know the work flow if I write tests for this new frame
> work. Do I simply write C files according to the frame work requirements
> and then run a script that generates the appropriate glue code?
> How are the RTEMS configurations provided for a particular test program?
> The plan is to have as much automation as possible, but we dont have all
the details yet. There will most likely be pre-generated skeleton test
files or templates to use to write new tests. This is the next step in my
project. I will post more information about this to ask for feedback once I
know more.
>> Next week I will be fixing any remaining issues with the output and also
>> implementing 16bit support for unity. Once complete this tool will
>> hopefully be
>> ready to use with RTEMS testing.
> Why does it matter for the test framework which word size an architecture
> has?
As far as I know Unity does not fully support some test functions specific
to 16bit, so my job is to make sure that it does. I will be investigating
this and other compatibility issues this week.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-devel mailing list
> rtems-devel at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-devel<http://www.rtems.org/mailman/listinfo/rtems-devel>
And to answer the previous questions, I have forked Unity on github so any
features that I develop specifically for RTEMS can be pulled to the
upstream repository once they are ready and if the maintainers find it
useful. And finally I do not have a developer blog but I may actually
create one in the future!
Thanks for the questions!
Marcin
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130916/37caffe1/attachment.html>
