[SOCIS] Testing Framework
Marcin Bujar
marcin.bujar at gmail.com
Mon Sep 23 22:32:41 UTC 2013
Hello all,
Another update on my SOCIS project. Last week I have been fixing bugs on
the modifications I have done to Unity to be used with the future RTEMS
testing framework.
For those interested the changes I have made so far are here:
https://github.com/marcinbujar/Unity/compare/ThrowTheSwitch:master...master
These additions to the unit testing tool will hopefully allow me work
towards higher automation of testing.
This week I have been using the new waf build system to compile RTEMS so
that I can start using unity for testing. So far I am still working my way
through build errors but I am making steady progress.
Marcin
On 16 September 2013 21:53, Marcin Bujar <marcin.bujar at gmail.com> wrote:
> On 16 September 2013 12:31, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Hello Marcin,
>> On 2013-09-15 22:34, Marcin Bujar wrote:
>>> Hi again,
>>> I would just like to update everybody that the work on my SOCIS project
>>> on
>>> RTEMS testing framework is going well. This week I worked on adding new
>>> features to the Unity unit testing tool, primarily adding JSON output
>>> support
>>> as mentioned in my previous update, but also looking how to compile the
>>> program
>>> on 16bit architecture so that it is executable on such RTEMS supported
>>> platforms.
>> it would be nice to know the work flow if I write tests for this new
>> frame work. Do I simply write C files according to the frame work
>> requirements and then run a script that generates the appropriate glue code?
>> How are the RTEMS configurations provided for a particular test program?
>> The plan is to have as much automation as possible, but we dont have all
> the details yet. There will most likely be pre-generated skeleton test
> files or templates to use to write new tests. This is the next step in my
> project. I will post more information about this to ask for feedback once I
> know more.
>>> Next week I will be fixing any remaining issues with the output and also
>>> implementing 16bit support for unity. Once complete this tool will
>>> hopefully be
>>> ready to use with RTEMS testing.
>> Why does it matter for the test framework which word size an architecture
>> has?
> As far as I know Unity does not fully support some test functions specific
> to 16bit, so my job is to make sure that it does. I will be investigating
> this and other compatibility issues this week.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> ______________________________**_________________
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/**listinfo/rtems-devel<http://www.rtems.org/mailman/listinfo/rtems-devel>
> And to answer the previous questions, I have forked Unity on github so any
> features that I develop specifically for RTEMS can be pulled to the
> upstream repository once they are ready and if the maintainers find it
> useful. And finally I do not have a developer blog but I may actually
> create one in the future!
> Thanks for the questions!
> Marcin
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130924/9783986d/attachment.html>
