[PATCH 1/1] DEVFS mknod stored path pointer, now path is copied instead
Daniel Hellstrom daniel at gaisler.com
Wed Sep 18 11:53:53 UTC 2013
 For RTEMS 4.10 branch.
 cpukit/libfs/src/devfs/devfs_mknod.c |    9 +++++++--
 1 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/cpukit/libfs/src/devfs/devfs_mknod.c b/cpukit/libfs/src/devfs/devfs_mknod.c
index d8e5a30..6df84a4 100644
--- a/cpukit/libfs/src/devfs/devfs_mknod.c
+++ b/cpukit/libfs/src/devfs/devfs_mknod.c
@@ -29,6 +29,7 @@ int devFS_mknod(
   int                       i;
   int                       slot;
+  int                       len;
   rtems_device_name_t      *device_name_table;
   rtems_device_major_number major;
   rtems_device_minor_number minor;
@@ -69,8 +70,12 @@ int devFS_mknod(
       rtems_set_errno_and_return_minus_one( ENOMEM );
   _ISR_Disable(level);
-  device_name_table[slot].device_name  = (char *)path;
-  device_name_table[slot].device_name_length = strlen(path);
+  len = strlen(path);
+  device_name_table[slot].device_name  = (char *)malloc(len);
+  if (!device_name_table[slot].device_name)
+      rtems_set_errno_and_return_minus_one(ENOMEM);
+  strcpy(device_name_table[slot].device_name, (char *)path);
+  device_name_table[slot].device_name_length = len;
   device_name_table[slot].major = major;
   device_name_table[slot].minor = minor;
   device_name_table[slot].mode  = mode;
1.7.0.4
