Coverity Scan on main_help.c
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Sep 17 15:00:36 UTC 2013
On 9/17/2013 9:16 AM, Sebastian Huber wrote:
> On 2013-09-17 16:05, Joel Sherrill wrote:
>> Hi
>> Take a peek at Issue 1063872 and 1063873. These are in main_help.c
>> and I think Scan is not happy with newlib's putchar() macro. It
>> increments the buffer pointer but it always ends up one past
>> what you use on any given call.
>> Since the pointer ends up pointing at something which is not
>> visibly dereferenced, Scan is not happy.
>> I think this is another intentional and OK to ignore but a
>> double check is also appreciated.
> The macro expansion is
> int myputchar(int c)
> return (--(((__getreent())->_stdout))->_w < 0 ?
> (((__getreent())->_stdout))->_w >= (((__getreent())->_stdout))->_lbfsize ?
> (*(((__getreent())->_stdout))->_p = (c)), *(((__getreent())->_stdout))->_p !=
> '\n' ? (int)*(((__getreent())->_stdout))->_p++ : __swbuf_r((__getreent()),
> '\n', ((__getreent())->_stdout)) : __swbuf_r((__getreent()), (int)(c),
> ((__getreent())->_stdout)) : (*(((__getreent())->_stdout))->_p = (c),
> (int)*(((__getreent())->_stdout))->_p++));
> so I would also complain ;-)
Wow! That's pretty ugly!!
The complaint itself is surprisingly simple.
CID 1063873 (#1 of 1): Incorrect pointer increment (NO_EFFECT)
no_effect_deref: The dereference in "(int)*__getreent()->_stdout->_p++"
has no effect.
This happens whether the value passed in is constant or not.
Do we ignore this or pass this report on to the newlib list for
further discussion?
