[PATCH]Add include guard to sparc.h when using assembly
Joel Sherrill Joel.Sherrill at OARcorp.com
Tue Sep 24 19:48:41 UTC 2013
My recollection is that basedefs.h doesn't have much you would want in asm. Need a test case for sure.
Gedare Bloom <gedare at rtems.org> wrote:
I don't think the problem is sparc.h, which already does include
within it some asm guards. Perhaps we should dig into the include to
figure out where the breakage occurs. A simple test case would be
helpful. I suspect the compiler winds up in basedefs.h and there are
missing guards there. basedefs.h does not look quite "asm" safe.
-Gedare
On Tue, Sep 24, 2013 at 3:31 PM, Joel Sherrill
<Joel.Sherrill at oarcorp.com> wrote:
> I think it is acceptable but sparc.h may have items valid to use from asm. Does it? Or if it completely C?
> Is it acceptable for an application to include rtems/asm.h? This seems
> suspect to me.
> On Mon, Sep 23, 2013 at 9:50 PM, Mohammed Khoory <mkhoory at eiast.ae> wrote:
>> Hi,
>> While working on a LEON3-based application, I was writing an assembly file
>> and so I included <rtems/asm.h> in order to use macros like PUBLIC() and
>> SYM(). When I tried to assemble my file (with sparc-rtems4.10-as) I got a
>> lot of "unknown opcode: typedef" errors. Looking at the headers I noticed
>> that it was including sparc.h, which has a bunch of typedefs.
>> This tiny patch fixes this problem by adding an #ifndef ASM around the
>> sparc.h include line.
>> If there are any comments let me know.
>> Regards,
>> Mohammed Khoory
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
