[PATCH]Add include guard to sparc.h when using assembly
Mohammed Khoory mkhoory at eiast.ae
Wed Sep 25 02:11:32 UTC 2013
Actually, I think I'm mistaken about that too, after looking at it more
clearly. It seems that I modified the 4.10.2 source a long time ago, added
an include <stdint.h> line to fix another problem I was having, and
forgotten about it, which caused this problem to crop up. Then when I looked
at it recently, I thought it was part of the actual release.
This was clearly a big screw-up on my part. Again I apologize for the whole
mess.
>-----Original Message-----
>From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf
>Of Gedare Bloom
>Sent: Wednesday, September 25, 2013 10:14 AM
>To: Mohammed Khoory
>Cc: Joel Sherrill; RTEMS Devel
>Subject: Re: [PATCH]Add include guard to sparc.h when using assembly
>Thanks! Contributions always welcome. :) So to be clear, the problem does
>not affect the 4.10 head?
>On Tue, Sep 24, 2013 at 8:45 PM, Mohammed Khoory <mkhoory at eiast.ae>
>wrote:
>> Please ignore my patch. It seems that I found the problem in
>> rtems-4.10.2, which is what I'm working with, and I thought I had
>> found the same problem in git, so I decided to send in the same fix I
>> did for 4.10.2.. but it seems that this issue isn't there in the git
>> version because everything seems to be included correctly.
>> Basedefs.h does have an include guard around stdint.h and the other
>> include lines, so I don't think there's a problem there.
>> Sorry for any time wasted. I'll try harder to make sure that my
>> patches are sound next time.
>Behalf
>>>Of Gedare Bloom
>>>Sent: Wednesday, September 25, 2013 4:42 AM
>>>To: Joel Sherrill
>>>Cc: Mohammed Khoory; rtems-devel at rtems.org
>>>I don't think the problem is sparc.h, which already does include
>>>within it
>> some
>>>asm guards. Perhaps we should dig into the include to figure out where
>>>the breakage occurs. A simple test case would be helpful. I suspect
>>>the
>> compiler
>>>winds up in basedefs.h and there are missing guards there. basedefs.h
>>>does not look quite "asm" safe.
>>>-Gedare
>>>On Tue, Sep 24, 2013 at 3:31 PM, Joel Sherrill
>>><Joel.Sherrill at oarcorp.com>
>>>wrote:
>>>> I think it is acceptable but sparc.h may have items valid to use
>>>> from
>> asm.
>>>Does it? Or if it completely C?
>>>> Gedare Bloom <gedare at rtems.org> wrote:
>>>> Is it acceptable for an application to include rtems/asm.h? This
>>>> seems suspect to me.
>>>> On Mon, Sep 23, 2013 at 9:50 PM, Mohammed Khoory
>>>wrote:
>>>>> Hi,
>>>>> While working on a LEON3-based application, I was writing an
>>>>> assembly file and so I included <rtems/asm.h> in order to use
>>>>> macros like
>>>>> PUBLIC() and SYM(). When I tried to assemble my file (with
>>>>> sparc-rtems4.10-as) I got a lot of "unknown opcode: typedef" errors.
>>>>> Looking at the headers I noticed that it was including sparc.h,
>>>>> which
>> has a
>>>bunch of typedefs.
>>>>> This tiny patch fixes this problem by adding an #ifndef ASM around
>>>>> the sparc.h include line.
>>>>> If there are any comments let me know.
>>>>> Regards,
>>>>> Mohammed Khoory
>>>>> _______________________________________________
>>>>> rtems-devel mailing list
>>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
