[PATCH 1/3] add simple atomic test cases into smpatomic08
WeiY
wei.a.yang at gmail.com
Sat Sep 28 06:54:36 UTC 2013
testsuites/smptests/smpatomic08/init.c | 106 ++++++++++++++++++++++++++++++++
1 file changed, 106 insertions(+)
diff --git a/testsuites/smptests/smpatomic08/init.c b/testsuites/smptests/smpatomic08/init.c
index c047ff0..5237a2f 100644
--- a/testsuites/smptests/smpatomic08/init.c
+++ b/testsuites/smptests/smpatomic08/init.c
@@ -454,10 +454,116 @@ static void test(void)
run_tests(ctx, 0);
+typedef void (*simple_test_body)(test_context *ctx);
+static void test_simple_atomic_add_body(test_context *ctx)
+ unsigned long a = 2, b = 1;
+ unsigned long c;
+ puts("=== atomic simple add test case ==\n");
+ _Atomic_Store_ulong(&ctx->atomic_value, a, ATOMIC_ORDER_RELAXED);
+ _Atomic_Fetch_add_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+ c = _Atomic_Load_ulong(&ctx->atomic_value, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(c == (a + b));
+static void test_simple_atomic_sub_body(test_context *ctx)
+ unsigned long c;
+ puts("=== atomic simple sub test case ==\n");
+ _Atomic_Fetch_sub_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(c == (a - b));
+static void test_simple_atomic_or_body(test_context *ctx)
+ unsigned long c;
+ puts("=== atomic simple or test case ==\n");
+ _Atomic_Fetch_or_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(c == (a | b));
+static void test_simple_atomic_and_body(test_context *ctx)
+ unsigned long c;
+ puts("=== atomic simple and test case ==\n");
+ _Atomic_Fetch_and_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(c == (a & b));
+static void test_simple_atomic_exchange_body(test_context *ctx)
+ unsigned long c;
+ puts("=== atomic simple exchange test case ==\n");
+ _Atomic_Exchange_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(c == b);
+static void test_simple_atomic_compare_exchange_body(test_context *ctx)
+ unsigned long c;
+ puts("=== atomic simple compare exchange test case ==\n");
+ _Atomic_Compare_exchange_ulong(&ctx->atomic_value, &a, b,
+ ATOMIC_ORDER_RELAXED, ATOMIC_ORDER_RELAXED);
+static const simple_test_body simple_test_bodies[] = {
+ test_simple_atomic_add_body,
+ test_simple_atomic_sub_body,
+ test_simple_atomic_or_body,
+ test_simple_atomic_and_body,
+ test_simple_atomic_exchange_body,
+ test_simple_atomic_compare_exchange_body,
+#define SIMPLE_TEST_COUNT RTEMS_ARRAY_SIZE(simple_test_bodies)
+static void simple_tests(void)
+ test_context *ctx = &test_instance;
+ size_t test;
+ for (test = 0; test < SIMPLE_TEST_COUNT; ++test) {
+ const simple_test_body *test_body = &simple_test_bodies[test];
+ (*test_body)(ctx);
static void Init(rtems_task_argument arg)
puts("\n\n*** TEST SMPATOMIC 8 ***");
+ simple_tests();
test();
puts("*** END OF TEST SMPATOMIC 8 ***");
1.7.9.5
