[PATCH] dosfs: Unsigned compared against 0
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Sep 5 17:57:35 UTC 2013
On 9/5/2013 12:50 PM, Gedare Bloom wrote:
> On Thu, Sep 5, 2013 at 1:31 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> Gedare.. are these from Coverity Scan? They seem
>> remarkably picky otherwise. :)
> Yes. I have some time to kill while I'm running some simulations.
>> If they are, ask when you want another run submitted.
> Will do. The patches need to be approved and committed first.
Just let me know when.
It would be nice if others could run them also. But that isn't a high
priority. I still have robbery clean up items WAY higher than that.
>> --joel
>> On 9/5/2013 12:10 PM, Gedare Bloom wrote:
>>> Fix the type of "cmpltd" to be ssize_t so that assigning it to -1
>>> will terminate processing as intended.
>>> cpukit/libfs/src/dosfs/msdos_dir.c | 2 +-
>>> 1 files changed, 1 insertions(+), 1 deletions(-)
>>> diff --git a/cpukit/libfs/src/dosfs/msdos_dir.c
>>> b/cpukit/libfs/src/dosfs/msdos_dir.c
>>> index 253203c..d7f6823 100644
>>> --- a/cpukit/libfs/src/dosfs/msdos_dir.c
>>> +++ b/cpukit/libfs/src/dosfs/msdos_dir.c
>>> @@ -78,7 +78,7 @@ msdos_dir_read(rtems_libio_t *iop, void *buffer, size_t
>>> count)
>>> const size_t buf_size = converter->buffer.size;
>>> uint32_t start = 0;
>>> ssize_t ret = 0;
>>> - uint32_t cmpltd = 0;
>>> + ssize_t cmpltd = 0;
>>> uint32_t j = 0, i = 0;
>>> uint32_t bts2rd = 0;
>>> uint32_t cur_cln = 0;
>> Joel Sherrill, Ph.D. Director of Research & Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
