[PATCH] dosfs: Unsigned compared against 0
Thu Sep 5 17:59:25 UTC 2013
FYI.. push them. :)
On 9/5/2013 12:57 PM, Joel Sherrill wrote:
> On 9/5/2013 12:50 PM, Gedare Bloom wrote:
>> On Thu, Sep 5, 2013 at 1:31 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>>> Gedare.. are these from Coverity Scan? They seem
>>> remarkably picky otherwise. :)
>> Yes. I have some time to kill while I'm running some simulations.
>>> If they are, ask when you want another run submitted.
>> Will do. The patches need to be approved and committed first.
> Just let me know when.
> It would be nice if others could run them also. But that isn't a high
> priority. I still have robbery clean up items WAY higher than that.
>>> --joel
>>> On 9/5/2013 12:10 PM, Gedare Bloom wrote:
>>>> Fix the type of "cmpltd" to be ssize_t so that assigning it to -1
>>>> will terminate processing as intended.
>>>>     cpukit/libfs/src/dosfs/msdos_dir.c |    2 +-
>>>>     1 files changed, 1 insertions(+), 1 deletions(-)
>>>> diff --git a/cpukit/libfs/src/dosfs/msdos_dir.c
>>>> b/cpukit/libfs/src/dosfs/msdos_dir.c
>>>> index 253203c..d7f6823 100644
>>>> --- a/cpukit/libfs/src/dosfs/msdos_dir.c
>>>> +++ b/cpukit/libfs/src/dosfs/msdos_dir.c
>>>> @@ -78,7 +78,7 @@ msdos_dir_read(rtems_libio_t *iop, void *buffer, size_t
>>>> count)
>>>>         const size_t       buf_size = converter->buffer.size;
>>>>         uint32_t           start = 0;
>>>>         ssize_t            ret = 0;
>>>> -    uint32_t           cmpltd = 0;
>>>> +    ssize_t            cmpltd = 0;
>>>>         uint32_t           j = 0, i = 0;
>>>>         uint32_t           bts2rd = 0;
>>>>         uint32_t           cur_cln = 0;
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
