[PATCH] dosfs: Unsigned compared against 0
Ralf Kirchner
ralf.kirchner at embedded-brains.de
Fri Sep 6 16:46:13 UTC 2013
Hi Gedare,
Iconv() does not return any negative values. It returns "(size_t)-1" in
case of an error and the number of non-reversibly converted characters
in case of success.
Thus please revert to size_t for the return value type and in addition
apply this patch:
cpukit/libfs/src/dosfs/msdos_conv_utf8.c | 11 ++++++++---
1 Datei geändert, 8 Zeilen hinzugefügt(+), 3 Zeilen entfernt(-)
diff --git a/cpukit/libfs/src/dosfs/msdos_conv_utf8.c
b/cpukit/libfs/src/dosfs/msdos_conv_utf8.c
index 18aebc6..6760d2e 100644
--- a/cpukit/libfs/src/dosfs/msdos_conv_utf8.c
+++ b/cpukit/libfs/src/dosfs/msdos_conv_utf8.c
@@ -69,10 +69,15 @@ static int msdos_utf8_convert_with_iconv(
*dst_size -= outbytes_left;
- if ( iconv_status > 0 ) {
- eno = EINVAL;
- } else if ( iconv_status < 0 ) {
+ if ( iconv_status == (size_t)-1 ) {
+ /* iconv() has detected an error. The most likely reason seems to +
be a too small outbuf */
eno = ENOMEM;
+ } else if ( iconv_status > 0 ) {
+ /* iconv_status contains the number of characters converted in a +
non-reversible way.
+ We want to use reversible conversions only.
+ Characters permitted within DOSFS names seem to be reversible. */
+ eno = EINVAL;
return eno;
1.7.10.4
Am 05.09.2013 19:18, schrieb Gedare Bloom:
> On Thu, Sep 5, 2013 at 1:17 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> Change the type for storing the return from iconv to be signed.
>> cpukit/libfs/src/dosfs/msdos_conv_utf8.c | 2 +-
>> 1 files changed, 1 insertions(+), 1 deletions(-)
>> diff --git a/cpukit/libfs/src/dosfs/msdos_conv_utf8.c b/cpukit/libfs/src/dosfs/msdos_conv_utf8.c
>> index a80db7e..18aebc6 100644
>> @@ -57,7 +57,7 @@ static int msdos_utf8_convert_with_iconv(
>> size_t outbytes_left = *dst_size;
>> char *inbuf = (void *) (uintptr_t) src;
>> char *outbuf = dst;
>> - size_t iconv_status;
>> + ssize_t iconv_status;
>> iconv_status = iconv(
> Note that iconv returns a size_t. Perhaps the return value should be
> cast explicitly to make this clear. newlib returns (size_t)-1 in case
> of an error in iconv.
>> desc,
>> 1.7.1
> rtems-devel mailing list
> rtems-devel at rtems.org
Embedded Brains GmbH
Ralf Kirchner Dornierstr. 4
D-82178 Puchheim Germany
email: ralf.kirchner at embedded-brains.de
Phone: +49-89-18 94 741-17
Fax: +49-89-18 94 741-08
