[PATCH] dosfs: Unsigned compared against 0
Fri Sep 6 16:53:50 UTC 2013
OK. Can you send the patch against the current master head (rather
than revert)? I am not able to commit today, but maybe someone else
can.
-Gedare
On Fri, Sep 6, 2013 at 12:46 PM, Ralf Kirchner
<ralf.kirchner at embedded-brains.de> wrote:
> Hi Gedare,
> Iconv() does not return any negative values. It returns "(size_t)-1" in
> case of an error and the number of non-reversibly converted characters
> in case of success.
> Thus please revert to size_t for the return value type and in addition
> apply this patch:
>  cpukit/libfs/src/dosfs/msdos_conv_utf8.c |   11 ++++++++---
>  1 Datei geändert, 8 Zeilen hinzugefügt(+), 3 Zeilen entfernt(-)
> diff --git a/cpukit/libfs/src/dosfs/msdos_conv_utf8.c
> b/cpukit/libfs/src/dosfs/msdos_conv_utf8.c
> index 18aebc6..6760d2e 100644
> --- a/cpukit/libfs/src/dosfs/msdos_conv_utf8.c
> +++ b/cpukit/libfs/src/dosfs/msdos_conv_utf8.c
> @@ -69,10 +69,15 @@ static int msdos_utf8_convert_with_iconv(
>    *dst_size -= outbytes_left;
> -  if ( iconv_status > 0 ) {
> -    eno = EINVAL;
> -  } else if ( iconv_status < 0 ) {
> +  if ( iconv_status == (size_t)-1 ) {
> +    /* iconv() has detected an error. The most likely reason seems to +
>       be a too small outbuf */
>      eno = ENOMEM;
> +  } else if ( iconv_status > 0 ) {
> +    /* iconv_status contains the number of characters converted in a +
>       non-reversible way.
> +       We want to use reversible conversions only.
> +       Characters permitted within DOSFS names seem to be reversible. */
> +    eno = EINVAL;
>    return eno;
> 1.7.10.4
> Am 05.09.2013 19:18, schrieb Gedare Bloom:
>> On Thu, Sep 5, 2013 at 1:17 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>> Change the type for storing the return from iconv to be signed.
>>>  cpukit/libfs/src/dosfs/msdos_conv_utf8.c |    2 +-
>>>  1 files changed, 1 insertions(+), 1 deletions(-)
>>> diff --git a/cpukit/libfs/src/dosfs/msdos_conv_utf8.c b/cpukit/libfs/src/dosfs/msdos_conv_utf8.c
>>> index a80db7e..18aebc6 100644
>>> @@ -57,7 +57,7 @@ static int msdos_utf8_convert_with_iconv(
>>>    size_t  outbytes_left = *dst_size;
>>>    char   *inbuf = (void *) (uintptr_t) src;
>>>    char   *outbuf = dst;
>>> -  size_t  iconv_status;
>>> +  ssize_t iconv_status;
>>>    iconv_status = iconv(
>> Note that iconv returns a size_t. Perhaps the return value should be
>> cast explicitly to make this clear. newlib returns (size_t)-1 in case
>> of an error in iconv.
>>>      desc,
>>> 1.7.1
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
> Embedded Brains GmbH
> Ralf Kirchner          Dornierstr. 4
> D-82178 Puchheim       Germany
> email: ralf.kirchner at embedded-brains.de
> Phone: +49-89-18 94 741-17
> Fax:   +49-89-18 94 741-08
