Feedback on Bash script to review BSP File Organization
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Sep 18 18:07:20 UTC 2013
Hi
I wanted to run the script and see how I could break it. :)
I ran it from libbsp/arm and got a few oddities and error
messages.
=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP configure.ac
/home/joel/rtems-4.11-work/rtems-testing/merge-helpers/check_submission:
line 232: test_its_not_there: command not found
The above is clearly an integration issue from merging the
scripts.
=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP configure.ac
RTEMS_BSP_CLEANUP_OPTIONS is NOT in ./configure.ac
The above appears to be from the older code being setup
to be inside a single BSP directory while the newer code
scans all BSPs for a single issue.
=== Checking for not using -O2
grep: make/custom/*.cfg: No such file or directory
=== Checking for turning on extra GCC warning checks
Same issue as previous but manifested differently.
=== Checking for timing information
Please run the timing tests and include the results.
Ditto.
I think the older tests need to be adjusted. Each may
need to be wrapped in a loop to cycle over each BSP
and invoke the test in the right subdirectory. Or the
test itself modified.
Also please point me to a case where a required method
is in the wrong file. I recall one in your previous output
but am missing it now.
A little clean up or a check that you are in a single BSP
directory is needed. I am not sure which is the right
solution. I was leaning to it working on a single BSP directory
since that is likely how someone will use it.
But supporting both modes correctly is useful.
