Feedback on Bash script to review BSP File Organization
Vipul Nayyar
nayyar_vipul at yahoo.com
Thu Sep 19 00:46:36 UTC 2013
Hello,
I also encountered the first error of command not found. Actually the real name of the function defined is test_its_NOT_there. I corrected this mistake but maybe didn't submit it in the patch. Will correct it.
BTW, the older code is written for evaluating a single bsp & mine for multiple but I've integrated the previous code in my file in the function which evaluates only a single bsp. I don't evaluate all bsps for a single issue. Each bsp is evaluated completely in its own order for different issues. So, the previous code should work properly. And I think it is.
Can you please tell me for which bsp you're getting the errors of RTEMS_BSP_CLEANUP_OPTIONS is NOT in ./configure.ac & grep ?
I checked the script without giving any extra options. And I'm not getting any problems in arm bsps.
The results that I mentioned were found in
* arm/gumstix : bspreset.c not compiled
* arm/gumstix : bsp_reset() present in file startup/bspstart.c
* powerpc/beatnik : bspreset.c not compiled
* powerpc/beatnik : bsp_reset() present in file include/bsp.h startup/reboot.c
* powerpc/mpc55xxevb : start.S not present in correct path
* powerpc/mpc55xxevb : bspreset.c not compiled
* powerpc/mpc55xxevb : bsp_reset() present in file startup/reset.c
* powerpc/mpc55xxevb : bspgetworkarea.c not compiled
* powerpc/mpc55xxevb : bsp_work_area_initialize() present in file startup/bspworkareainit.c
Either you can check them manually or the script is also giving me the same output with these warnings.
Regards
Vipul Nayyar
________________________________
To: Vipul Nayyar <nayyar_vipul at yahoo.com>; "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Wednesday, 18 September 2013 11:37 PM
Subject: Feedback on Bash script to review BSP File Organization
Hi
I wanted to run the script and see how I could break it. :)
I ran it from libbsp/arm and got a few oddities and error
messages.
=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP configure.ac
/home/joel/rtems-4.11-work/rtems-testing/merge-helpers/check_submission:
line 232: test_its_not_there: command not found
The above is clearly an integration issue from merging the
scripts.
=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP configure.ac
The above appears to be from the older code being setup
to be inside a single BSP directory while the newer code
scans all BSPs for a single issue.
=== Checking for not using -O2
grep: make/custom/*.cfg: No such file or directory
=== Checking for turning on extra GCC warning checks
Same issue as previous but manifested differently.
=== Checking for timing information
Please run the timing tests and include the results.
Ditto.
I think the older tests need to be adjusted. Each may
need to be wrapped in a loop to cycle over each BSP
and invoke the test in the right subdirectory. Or the
test itself modified.
Also please point me to a case where a required method
is in the wrong file. I recall one in your previous output
but am missing it now.
A little clean up or a check that you are in a single BSP
directory is needed. I am not sure which is the right
solution. I was leaning to it working on a single BSP directory
since that is likely how someone will use it.
But supporting both modes correctly is useful.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130919/755fa4b8/attachment-0001.html>
