[rtems commit] score: Add _Scheduler_Highest_priority_of_two()
Tue Apr 1 15:03:06 UTC 2014
Just a friendly reminder that macros or inlines which include
conditional expressions result in having to test every path
of the branches everywhere they are inlined.
I doubt this one is a problem but we have to be aware that
inlining complicated conditionals negatively impacts branch
coverage testing.
--joel
On 3/31/2014 3:09 AM, Sebastian Huber wrote:
> Module:    rtems
> Branch:    master
> Commit:    298d0fda9df75d2b7c4b9329a78845cb1398342b
> Changeset: http://git.rtems.org/rtems/commit/?id=298d0fda9df75d2b7c4b9329a78845cb1398342b
> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date:      Mon Mar 24 07:44:00 2014 +0100
> Use inline functions instead of macros for
> _Scheduler_Is_priority_lower_than() and
> _Scheduler_Is_priority_higher_than().
>  cpukit/score/include/rtems/score/schedulerimpl.h |   36 +++++++++++++++++----
>  1 files changed, 29 insertions(+), 7 deletions(-)
> diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
> index 7fbaf54..e70e466 100644
> --- a/cpukit/score/include/rtems/score/schedulerimpl.h
> +++ b/cpukit/score/include/rtems/score/schedulerimpl.h
> @@ -269,18 +269,40 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Generic_block(
> - * Macro testing whether @a p1 has lower priority than @a p2
> - * in the intuitive sense of priority.
> + * @brief Returns true if @p1 encodes a lower priority than @a p2 in the
> + * intuitive sense of priority.
> -#define _Scheduler_Is_priority_lower_than( _p1, _p2 ) \
> -  (_Scheduler_Priority_compare(_p1,_p2) < 0)
> +RTEMS_INLINE_ROUTINE bool _Scheduler_Is_priority_lower_than(
> +  Priority_Control p1,
> +  Priority_Control p2
> +  return _Scheduler_Priority_compare( p1,  p2 ) < 0;
> - * Macro testing whether @a p1 has higher priority than @a p2
> + * @brief Returns true if @p1 encodes a higher priority than @a p2 in the
> +RTEMS_INLINE_ROUTINE bool _Scheduler_Is_priority_higher_than(
> +  return _Scheduler_Priority_compare( p1,  p2 ) > 0;
> + * @brief Returns the priority encoding @a p1 or @a p2 with the higher priority
> -#define _Scheduler_Is_priority_higher_than( _p1, _p2 ) \
> -  (_Scheduler_Priority_compare(_p1,_p2) > 0)
> +RTEMS_INLINE_ROUTINE Priority_Control _Scheduler_Highest_priority_of_two(
> +  return _Scheduler_Is_priority_higher_than( p1, p2 ) ? p1 : p2;
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
