[PATCH 01/10] score: Add get/set affinity to Scheduler Framework.
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Apr 2 18:07:58 UTC 2014
On 4/2/2014 12:40 PM, Jennifer Averett wrote:
> Sorry for the late response to this one:
> Fixing the typo and cut and paste problems.
> The default scheduler is the default for the SMP system now.
> By default affinity is not supported.
When we get a functional scheduler with affinity, the default
could change.
Currently for SMP builds but configured with 1 core, we use
the Deterministic Priority Scheduler (uniprocessor). Chris has
asked about switching to an SMP aware scheduler even for
those. I can see both perspectives but we still want coverage
on all schedulers. This could require adding tests specifically
for the DPS.
> Jennifer
>> -----Original Message-----
>> From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On
>> Behalf Of Gedare Bloom
>> Sent: Monday, March 24, 2014 3:10 PM
>> To: Jennifer Averett
>> Cc: RTEMS Devel
>> Subject: Re: [PATCH 01/10] score: Add get/set affinity to Scheduler
>> Framework.
>> On Mon, Mar 24, 2014 at 2:39 PM, Jennifer <jennifer.averett at oarcorp.com>
>> wrote:
>>> From: Jennifer Averett <jennifer.averett at oarcorp.com>
>>> cpukit/score/Makefile.am | 2 +
>>> cpukit/score/include/rtems/score/scheduler.h | 58
>>> cpukit/score/include/rtems/score/schedulerimpl.h | 32 ++++++++++++
>>> .../score/include/rtems/score/schedulerpriority.h | 11 +++-
>>> .../include/rtems/score/schedulerprioritysmp.h | 6 ++-
>>> .../score/include/rtems/score/schedulersimplesmp.h | 4 +-
>>> cpukit/score/src/schedulerdefaultgetaffinity.c | 41 +++++++++++++++
>>> cpukit/score/src/schedulerdefaultsetaffinity.c | 32 ++++++++++++
>>> 8 files changed, 182 insertions(+), 4 deletions(-) create mode
>>> 100644 cpukit/score/src/schedulerdefaultgetaffinity.c
>>> create mode 100644 cpukit/score/src/schedulerdefaultsetaffinity.c
>>> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am index
>>> aeee4b6..67cc802 100644
>>> --- a/cpukit/score/Makefile.am
>>> +++ b/cpukit/score/Makefile.am
>>> @@ -131,6 +131,8 @@ libscore_a_SOURCES += src/schedulersmpstartidle.c
>>> libscore_a_SOURCES += src/smp.c libscore_a_SOURCES += src/cpuset.c
>>> libscore_a_SOURCES += src/cpusetprintsupport.c
>>> +libscore_a_SOURCES += src/schedulerdefaultgetaffinity.c
>>> +libscore_a_SOURCES += src/schedulerdefaultsetaffinity.c
>>> endif
>>> ## CORE_APIMUTEX_C_FILES
>>> diff --git a/cpukit/score/include/rtems/score/scheduler.h
>>> b/cpukit/score/include/rtems/score/scheduler.h
>>> index ced3c00..a0e36f3 100644
>>> --- a/cpukit/score/include/rtems/score/scheduler.h
>>> +++ b/cpukit/score/include/rtems/score/scheduler.h
>>> @@ -22,6 +22,9 @@
>>> #include <rtems/score/percpu.h>
>>> #include <rtems/score/chain.h>
>>> #include <rtems/score/priority.h>
>>> +#if defined(__RTEMS_HAVE_SYS_CPUSET_H__) &&
>> defined(RTEMS_SMP)
>>> + #include <sys/cpuset.h>
>>> +#endif
>>> #ifdef __cplusplus
>>> extern "C" {
>>> @@ -98,6 +101,24 @@ typedef struct {
>>> * @see _Scheduler_Start_idle().
>>> void ( *start_idle )( Thread_Control *thread, Per_CPU_Control
>>> *processor );
>> defined(RTEMS_SMP)
>>> + * @brief Obtain the processor affinity for a thread.
>>> + * @see _Scheduler_Get_affinity().
>>> + int ( *get_affinity )( Thread_Control *thread, size_t cpusetsize,
>>> +cpu_set_t *cpuset );
>> 1 newline please
>>> + * @brief Set the processor affinity for a thread.
>>> + * @see _Scheduler_Set_affinity().
>>> + int ( *set_affinity )( Thread_Control *thread, size_t cpusetsize,
>>> +cpu_set_t *cpuset ); #endif
>>> } Scheduler_Operations;
>>> @@ -184,6 +205,43 @@ void _Scheduler_default_Start_idle(
>>> Per_CPU_Control *processor
>> defined(RTEMS_SMP)
>>> + * @brief Get affinity for the default scheduler.
>>> + * @param[in] thread The associated thread.
>>> + * @param[in] cpusetsize The size of the cpuset.
>>> + * @param[out] cpuset Affinity set containing all CPUs.
>>> + * @retval 0 Successfully got cpuset
>>> + * @retval -1 The cpusetsize is invalid for the system
>>> + int _Scheduler_default_Get_affinity(
>>> + Thread_Control *thread,
>>> + size_t cpusetsize,
>>> + cpu_set_t *cpuset
>>> + * @brief Set affinity for the default scheduler.
>>> + * @param[in] cpuset Affinity new affinity set.
>>> + * This method always returns successful and does not save
>>> + * the cpuset.
>>> + int _Scheduler_default_Set_affinity(
>>> + cpu_set_t *cpuset
>>> +#endif
>>> #ifdef __cplusplus
>>> diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h
>>> b/cpukit/score/include/rtems/score/schedulerimpl.h
>>> index 7fbaf54..021b50f 100644
>>> --- a/cpukit/score/include/rtems/score/schedulerimpl.h
>>> +++ b/cpukit/score/include/rtems/score/schedulerimpl.h
>>> @@ -240,6 +240,38 @@ RTEMS_INLINE_ROUTINE void
>>> ( *_Scheduler.Operations.start_idle )( thread, processor ); }
>> defined(RTEMS_SMP)
>>> + * @param[in,out] thread The idle thread for the processor.
>> idle?
>>> + * @parma[out] cpuset The processor affinity for this thread
>>> + RTEMS_INLINE_ROUTINE int _Scheduler_Get_affinity(
>>> + cpu_set_t *cpuset
>>> + return (*_Scheduler.Operations.get_affinity)( thread, cpusetsize,
>>> + cpuset ); }
>> idle?
>>> + * @parma[in] cpuset The processor affinity for this thread
>>> + RTEMS_INLINE_ROUTINE int _Scheduler_Set_affinity(
>>> + cpu_set_t *cpuset
>>> + return (*_Scheduler.Operations.set_affinity)( thread, cpusetsize,
>>> +cpuset );
>>> +#endif
>>> RTEMS_INLINE_ROUTINE void _Scheduler_Update_heir(
>>> Thread_Control *heir,
>>> bool force_dispatch
>>> diff --git a/cpukit/score/include/rtems/score/schedulerpriority.h
>>> b/cpukit/score/include/rtems/score/schedulerpriority.h
>>> index 605ab39..a9a46e9 100644
>>> --- a/cpukit/score/include/rtems/score/schedulerpriority.h
>>> +++ b/cpukit/score/include/rtems/score/schedulerpriority.h
>>> @@ -34,6 +34,14 @@ extern "C" {
>> defined(RTEMS_SMP)
>>> + #define SCHEDULER_PRIORITY_ADDITIONAL_SMP_ENTRY_POINTS \
>>> + _Scheduler_default_Get_affinity, /* get affinity entry point */ \
>>> + _Scheduler_default_Set_affinity /* set affinity entry point */
>>> +#else
>>> +#endif
>>> * Entry points for the Deterministic Priority Based Scheduler.
>>> @@ -53,7 +61,8 @@ extern "C" {
>>> _Scheduler_priority_Priority_compare, /* compares two priorities */ \
>>> _Scheduler_default_Release_job, /* new period of task */ \
>>> _Scheduler_default_Tick, /* tick entry point */ \
>>> - _Scheduler_default_Start_idle /* start idle entry point */ \
>>> + _Scheduler_default_Start_idle, /* start idle entry point */ \
>>> + SCHEDULER_PRIORITY_ADDITIONAL_SMP_ENTRY_POINTS \
>> Do we support configuring an SMP system with this scheduler?
>>> diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmp.h
>>> b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
>>> index b0e5fad..bee4232 100644
>>> --- a/cpukit/score/include/rtems/score/schedulerprioritysmp.h
>>> +++ b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
>>> @@ -48,7 +48,7 @@ extern "C" {
>>> - * @brief Entry points for the Simple SMP Scheduler.
>>> + * @brief Entry points for the Priority SMP Scheduler.
>>> #define SCHEDULER_PRIORITY_SMP_ENTRY_POINTS \
>>> @@ -66,7 +66,9 @@ extern "C" {
>>> _Scheduler_priority_Priority_compare, \
>>> _Scheduler_default_Release_job, \
>>> _Scheduler_default_Tick, \
>>> - _Scheduler_SMP_Start_idle \
>>> + _Scheduler_SMP_Start_idle, \
>>> + _Scheduler_default_Get_affinity, \
>>> + _Scheduler_default_Set_affinity \
>>> void _Scheduler_priority_SMP_Initialize( void ); diff --git
>>> a/cpukit/score/include/rtems/score/schedulersimplesmp.h
>>> b/cpukit/score/include/rtems/score/schedulersimplesmp.h
>>> index 1a69358..e8cd54b 100644
>>> --- a/cpukit/score/include/rtems/score/schedulersimplesmp.h
>>> +++ b/cpukit/score/include/rtems/score/schedulersimplesmp.h
>>> @@ -68,7 +68,9 @@ extern "C" {
>>> void _Scheduler_simple_smp_Initialize( void ); diff --git
>>> a/cpukit/score/src/schedulerdefaultgetaffinity.c
>>> b/cpukit/score/src/schedulerdefaultgetaffinity.c
>>> new file mode 100644
>>> index 0000000..fde9b01
>>> --- /dev/null
>>> +++ b/cpukit/score/src/schedulerdefaultgetaffinity.c
>>> @@ -0,0 +1,41 @@
>>> + * @file
>>> + * @brief Scheduler Default Get Affinity Operation
>>> + * @ingroup ScoreScheduler
>>> + * COPYRIGHT (c) 2014.
>>> + * On-Line Applications Research Corporation (OAR).
>>> + * The license and distribution terms for this file may be
>>> + * found in the file LICENSE in this distribution or at
>>> + * http://www.rtems.org/license/LICENSE.
>>> +#if HAVE_CONFIG_H
>>> + #include "config.h"
>>> +#endif
>>> +#include <rtems/score/schedulerimpl.h> #include
>>> +<rtems/score/cpusetimpl.h>
>>> +int _Scheduler_default_Get_affinity(
>>> + cpu_set_t *cpuset
>>> + const CPU_set_Control *ctl;
>>> + ctl = _CPU_set_Default();
>>> + if ( cpusetsize == ctl->setsize ) {
>> shouldn't this be !=
>>> + return -1;
>>> + CPU_COPY( cpuset, ctl->set );
>>> + return 0;
>>> diff --git a/cpukit/score/src/schedulerdefaultsetaffinity.c
>>> b/cpukit/score/src/schedulerdefaultsetaffinity.c
>>> index 0000000..9c1eef0
>>> --- /dev/null
>>> +++ b/cpukit/score/src/schedulerdefaultsetaffinity.c
>>> @@ -0,0 +1,32 @@
>>> + * @file
>>> + * @brief Scheduler Default Set Affinity Operation
>>> +#if HAVE_CONFIG_H
>>> +#endif
>>> +int _Scheduler_default_Set_affinity(
>>> + cpu_set_t *cpuset
>>> + return 0;
>>> 1.8.1.4
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
