extra memory and queue memory was Re: [rtems commit] rhealstone/rhmlatency: Fix configuration
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Apr 4 15:10:33 UTC 2014
We generally need to make a sweep through the tests
for any cases that:
+ configure a message queue and don't reserve memory for
message buffers.
+ Use CONFIGURE_MEMORY_OVERHEAD. This is supposed
to be a work around.
+ Define CONFIGURE_EXECUTIVE_RAM_SIZE explicitly rather than
letting confdefs.h compute it. I hope none actually do this but
we should check.
--joel
On 4/4/2014 9:59 AM, Sebastian Huber wrote:
> Module: rtems
> Branch: master
> Commit: cae120e23ce0f5923c5949a8de1d2eae7ef76a78
> Changeset: http://git.rtems.org/rtems/commit/?id=cae120e23ce0f5923c5949a8de1d2eae7ef76a78
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date: Fri Apr 4 16:32:10 2014 +0200
> testsuites/rhealstone/rhmlatency/mlatency.c | 2 ++
> 1 files changed, 2 insertions(+), 0 deletions(-)
> diff --git a/testsuites/rhealstone/rhmlatency/mlatency.c b/testsuites/rhealstone/rhmlatency/mlatency.c
> index 4ddf808..10104e6 100644
> --- a/testsuites/rhealstone/rhmlatency/mlatency.c
> +++ b/testsuites/rhealstone/rhmlatency/mlatency.c
> @@ -148,6 +148,8 @@ rtems_task Task02( rtems_task_argument ignored )
> #define CONFIGURE_MAXIMUM_TASKS 3
> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 1
> +#define CONFIGURE_MESSAGE_BUFFER_MEMORY \
> + CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(1, MESSAGE_SIZE)
> #define CONFIGURE_TICKS_PER_TIMESLICE 0
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
