Fwd: Re: [PATCH 00/14] Removal of or32/openrisc and introduction of or1k
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Apr 23 15:27:56 UTC 2014
Looks like the OpenRISC is now in binutils.
-------- Original Message --------
Subject: Re: [PATCH 00/14] Removal of or32/openrisc and introduction of
or1k
Date: Wed, 23 Apr 2014 00:35:04 -0500
To: Christian Svensson <blue at cmd.nu>
CC: Nicholas Clifton <nickc at redhat.com>, "binutils at sourceware.org"
<binutils at sourceware.org>
On Tue, Apr 22, 2014 at 08:06:13PM +0100, Christian Svensson wrote:
> Hi,
> On Tue, Apr 22, 2014 at 4:02 PM, Nicholas Clifton <nickc at redhat.com> wrote:
> > They have been committed.
> Thanks!
--enable-maintainer-mode --enable-cgen-maint=yes --enable-targets=all
cgen -s /src/binutils-gdb/opcodes/../cgen/cgen-opc.scm -s /src/binutils-gdb/opcodes/../cgen -v -f opinst -m all -a /src/binutils-gdb/opcodes/../cpu/or1k.cpu -OPC /src/binutils-gdb/opcodes/../cpu/or1k.opc -H tmp-9072-desc.h1 -C tmp-9072-desc.c1 -O tmp-9072-opc.h1 -P tmp-9072-opc.c1 -L tmp-9072-ibld.in1 -A tmp-9072-asm.in1 -D tmp-9072-dis.in1 -Q tmp-9072-opinst.c1
Setting option `opinst' to "".
Loading cpu description /src/binutils-gdb/opcodes/../cpu/or1k.cpu ...
machs: all
isas: all
options: opinst
trace:
diags:
Including file /src/binutils-gdb/opcodes/../cpu/simplify.inc ...
Including file /src/binutils-gdb/opcodes/../cpu/or1kcommon.cpu ...
Including file /src/binutils-gdb/opcodes/../cpu/or1korbis.cpu ...
Including file /src/binutils-gdb/opcodes/../cpu/or1korfpx.cpu ...
Processing cpu description /src/binutils-gdb/opcodes/../cpu/or1k.cpu ...
Canonicalizing instruction semantics ...
ERROR:
While canonicalizing (set () BI sys-sr-ov (mul-o2flag WI rA rB)), operand #3 of:
(sequence
(sequence
(set BI sys-sr-ov (mul-o2flag WI rA rB))
(set BI sys-sr-cy (mul-o1flag WI rA rB))
(set rD (mul WI rA rB)))
(if (andif sys-sr-ov sys-sr-ove)
(c-call VOID "@cpu at _exception" pc EXCEPT-RANGE)))
@ /src/binutils-gdb/opcodes/../cpu/simplify.inc:173:3: referenced from:
/src/binutils-gdb/opcodes/../cpu/simplify.inc:174:2(end): referenced from:
/src/binutils-gdb/opcodes/../cpu/or1korbis.cpu:720:1: referenced from:
/src/binutils-gdb/opcodes/../cpu/or1korbis.cpu:736:2(end):
simplify.inc:173:3: canonicalizing semantics of l-mul: unknown rtx function: (mul-o2flag WI rA rB)
No backtrace available.
make[5]: *** [run-cgen] Error 1
Alan Modra
Australia Development Lab, IBM
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140423/aa308159/attachment.html>
